I Broke my Acer's inverter 6 pin connector
Discussion in 'Acer' started by Shakeeb iringa, Jan 6, 2012.
  1. Shakeeb iringa
    Shakeeb iringa Newbie
    Hi everyone i am new in this forum, i hope i will get a good support from you guys as the others are getting
    i was replacing my LCD screen on my Acer Aspire 4310 Laptop after i put in the new LCD nothing showed unless you flash a light towards the LCD you could see a faded image,
    so i thought i would better replace the inverter as well so i got a new inverter now when i was pulling out the 6-pin connector from the inverter it broke into pieces and the cables are mixed up now i cant figure out on what sequence or color should i arrange the cable into the connector
    hope to hear from you soon
    :confused:
  2. ajbutch123
    ajbutch123 Notebook Consultant
    I'm plannng on taking my aspire 6920g screen apart tonight to check what cable I have, so if mine is the same ill draw you up a color coded diagram.
    Good luck!
  3. tuηay
    tuηay o TuNaY o
    Welcome to the forum Shakeeb iringa!
    Best you actually can do is to search on youtube etc. to find a screen replacement video and check it out.. Or wait for ajbutch123 to give you the result..
    Either way, Good Luck and let us know the result!
  4. ajbutch123
    from right to left: brown, orange, yellow, green, red, and black
    Good luck! I hope this helps.
  5. Shakeeb iringa
    Hi Ajbutch thanks for your assistance i checked with your color code but unfortunately i dont have those colors i have brown,black,purple,grey,white and pink so still stuck with the problem
    Hey tunay,
    i am trying to go around you tube and see what i come up with
    thanks for the advice buddy
  6. Shakeeb iringa
    guys i went around youtube but i cant find anything in there
  7. tuηay
    tuηay o TuNaY o
    Sorry to hear that. I have to be honest no other idea about where you can get the informtion... If you find another 4310 owner, maybe you can kindly ask for him to check.. Good Luck!!
  8. PatchySan
    PatchySan Om Noms Kit Kat
    Have you tried using the Acer Service Manual for your model to see if that helps things?
  9. tuηay
    tuηay o TuNaY o
    Wait a minute, ASUS? You ment ACER right? :)
  10. niffcreature
    niffcreature computer lesbian
    I have a umm 4330 and 4720 or something.
    I don't think they share the same LCD cable. Ill check in a second. They are incredibly similar models but have slight strange differences.
    I think one of them is the same motherboard and LCD cable as yours so if you need the pinout you are in luck. :)
