HTWingNut's Sager NP9150 (Clevo P150EM) Review with LOTS of 680m benchmarks!
Discussion in 'Sager/Clevo Reviews & Owners' Lounges' started by HTWingNut, Jul 13, 2012.
  1. HTWingNut
    HTWingNut Potato
    Did you install the correct audio drivers? Go into your device manager and look and see if there is an exclamation point next to your sound card or listed under "unknown device" or something. Perhaps drivers or wrong drivers were installed.
  2. mrblings
    mrblings Notebook Consultant
    nop there is nothing with exclamation point.
    in the sound, video and game controllers, there are
    High definition audio device
    NVIDIA high definition audio
    Just like that.
    lol i dled the realktek hd audio manager from the disc i got and now it works. thanks tho haha
  3. Mahoo
    Mahoo Notebook Enthusiast
    Htwingnut great review quick question is your cpu underclocked from factory like my 3820qm unless i turn on throttlestop my cpu is limited to 2300mhz on high performance and plugged in but with throttlestop can hit max turbo
    Ps my p150em was purchased from metabox in australia a clevo retailer is not a sager so am not sure if metabox has underclocked or clevo
  4. HTWingNut
    HTWingNut Potato
    No, my i7-3610QM will run 3.1 GHz with all four cores maxed (i.e. Prime95) without Throttlestop.
  5. RGSPro
    RGSPro Notebook Enthusiast
    I noticed you got the optical bay caddy in yours- I did the same thing as you can buy an optical drive on the cheap, but I noticed that your bezel does not have non-functional optical drive buttons (which is what Xotic told me I would get). Did yours come with the optical drive replacement bezel in case you wanted to put in your own optical drive?
  6. HTWingNut
    HTWingNut Potato
    Yep, I got a bezel for an optical drive too. :)
  7. ExMM
    ExMM Notebook Evangelist
    Excellent review HTwingnut's! +1 rep
    I was wondering out of curiosity, what happened to your NP6110?
    I got a friend who has it too....
  8. HTWingNut
    HTWingNut Potato
    It was, erm, user error I believe. Got a little too anxious with pliers and wires, lol. New motherboard incoming.
  9. ExMM
    LOL.... I should have guess it...your review is soo accurate.. ;)
    It reminds me of years ago, when I burned the motherboard on my old HP pavilion while I was flashing a modded BIOS... :D
  10. Quagmire LXIX
    Quagmire LXIX Have Laptop, Will Travel!
    Hey Nut, nice review +rep! Finally something I can work with. Here is a 7970m R4 comparison on the Crysis 2 benchmarks.
    First 3 are stock clock 850x1200, next 3 are 950x1500 OC. Green gets great MINs as I've always noticed over the years.
