HTWingNut's Sager NP9150 (Clevo P150EM) Review with LOTS of 680m benchmarks!
Discussion in 'Sager/Clevo Reviews & Owners' Lounges' started by HTWingNut, Jul 13, 2012.
  1. jaug1337
    jaug1337 de_dust2
    As it clearly says at Settings
    Notice it says Kill-A-Watt (hardware) watt meter for measuring power consumption
    Did you install the modded INF?
  2. HTWingNut
    HTWingNut Potato
  3. Tonrac
    Tonrac Notebook Evangelist
    Do you plan to use/test the OV/OC bios made by saltius and provided by cloudfire?
  4. jaug1337
    jaug1337 de_dust2
    good question!
    are you HT?
  5. HTWingNut
    HTWingNut Potato
    I'm asking about it. I want to make sure it's stable first, but looking like it is. Then I can do all my benchmark compares. Seems they got the issue sorted out with the memory controller and gpu core bouncing around due to some power parameter in the BIOS.
  6. jaug1337
    jaug1337 de_dust2
    Indeed! svl7 used his magic tricks and voila
    good luck when you get it, dont brick this machine too please
  7. HTWingNut
    HTWingNut Potato
    LOL. No hard mods on my NP9150. Not this baby.
  8. Achusaysblessyou
    Achusaysblessyou eecs geek ftw :D
  9. HTWingNut
    HTWingNut Potato
    That's pretty much the Kill-A-Watt I have. Problem is there is no peak wattage feature so I have to monitor it through the benchmarks. I do make note of where the peak was in each benchmark and usually it's consistent whether I overclock or run on another machine, so at least I can monitor that part. But it would be nice to just run and walk away and get the data at the end of the run. I can't find anything that will give me peak watts though. Should be a simple feature to implement.
  10. mrblings
    mrblings Notebook Consultant
    nice review.
    i have a question on thx trustudio pro sound. i have a NP8130 but when i open it from the system tray, it is all grayed out and when i click audio selection... it says
    "there is no supported audio device available." why does this happen?
