HQ Sound Cards solution for a Laptop?
Discussion in 'Hardware Components and Aftermarket Upgrades' started by kosta20071, Jan 28, 2013.
  1. kosta20071
    kosta20071 Notebook Consultant
    Hey,
    I own dell Precision M6600 and I wanted to know If connecting HQ sound cards like Xonar was possible.
    There is little variety of sound cards with USB connection like Creative X-FI 5.1 which sounds awful.
    Thanks.
  2. tijo
    tijo Sacred Blame
    Do you mean the desktop cards, if yes you'd need some kind of converter to go from PCI/PCI-E to expresscard, USB or whatever. You should look at USB DACs instead, something like leckerton dacs or even the FiiOs which are decent for their price.
  3. kaltmond
    kaltmond Clepple
    I use this for a 1820M PCI card. :D
  4. Prostar Computer
    Outside the USB portable sound cards, DACs probably are the best solution as far as quality goes. I'm guessing that since you want HQ sound, you have HQ files? USB DACs are glorified as sounding better than CDs. You won't do it justice with 128 Kbps audio files though. ;)
  5. Nemix77
    Nemix77 Notebook Deity
    This...LMAO
    If you've got professional soldering skills in theory you can change the audio chip on your laptop to more recent and probably better chip than the one you've got right now.
    Realtek HD > Creative when it comes to sound quality, Xonar better than both; Creative king of gaming till Vista came along.
    Edit:
    Almost forgot about this: http://www.asus.com/Sound_Cards_and_DigitaltoAnalog_Converters/Xonar_U3/
  6. cdoublejj
    cdoublejj Notebook Deity
    Aside from DACs there was 1 or 2 good sound cards for laptops, they are older ones and i don't remember the mode/names. Honestly good headphones go a long way too.
  7. kaltmond
    kaltmond Clepple
    M6600 has Expresscard, you can use Echo Indigo IOx/DJx, or RME HDSPe Expresscard + Multiface.
  8. baii
    baii Sone
  9. cdoublejj
    Don't forget Optical DACs (optical out)
