HPdv3t - Intel P7550 running consistently 88C-94C - problem?
Discussion in 'Hardware Components and Aftermarket Upgrades' started by jsoell, May 13, 2010.
  1. Johnny T
    Johnny T Notebook Nobel Laureate
    No. Whilst I agree HP's Pavilion line does not have the best cooling design around, no notebook should reach that kinda temperature under the uses jsoell described above. Whilst the solutions mentioned above will cool down the notebook, ultimately the problem lays elsewhere.
  2. BamAlmighty
    BamAlmighty Notebook Consultant
    first of all... check to make sure you have the right thermal spec set in the hwmonitorw.ini file, the CPU_0_TJMAX value needs to match your processor which should be 90.
    Otherwise your temp value is going to be way high.
