HP ZBook 17 G6: Touchscreen UHD screen (and other questions)
Discussion in 'HP Business Class Notebooks' started by Kyle, Jun 8, 2020.
  1. Kyle
    Kyle JVC SZ2000 Dual-Driver Headphones
    Anyone have any reviews on the HP ZBook 17 G6 Touchscreen 3840x2160 screen?
    I'm guessing it is not a matte screen?
    Does it support a pen?
    Another question: the HP site says one of the SSD slots is not a customer serviceable part. Does the installaed first M.2 SSD put in a customer serviceable slot, or in the non-customer serviceable slot?
  2. ichime
    ichime Notebook Elder
    I have the touchscreen G5 which is basically the same thing as the G6 except the motherboard config with the CPU and WiFi are different.
    The stylus I used for my old tablet works on the touchscreen, though I’m not sure about the more precise ones HP sells for the Zbook X360. It may be worth a shot to try if it’s at a good price.
    as for the SSD, the one that was preinstalled is in the non-customer serviceable slot as with the first two memory channels. You’d have to remove the entire motherboard to access it. HP has a series of YouTube videos that shows you how to do it step by step.
    Kyle likes this.
  3. Kyle
    Thanks! Could you link to the Youtube videos?
  4. ichime
