HP WLan slows down my startup! help!
Discussion in 'HP' started by cotton_mouth, Sep 27, 2007.
  1. cotton_mouth
    cotton_mouth Notebook Geek
    hey guys. i bought HP Pavilion DV2500t a month ago. i noticed that when i start up my comp, everything loads up straightaway except for my wireless lan. at first i thought it was norton anti virus slowing things down but that's not the case as i have uninstalled norton and the problem is still there.
    the wlan easily slows down the start up by about 2 mins. what happens is that when i input my password, everything loads up almost at once (including pc-cillin internet security) and then the computer goes into an idle state for about 2 mins after which the dsplay will flicker and then wlan will load up.
    may i know why wlan takes so long to load up? pls help cos it's really very annoying. thanks!
  2. shuvo
    shuvo Notebook Enthusiast
    My brothers dv8300t did exactly the same thing. He uninstalled the HP's software and used Vista's in-built WLAN capability and the problem went away. I don't know if this will work in this case but why not try it!
  3. cotton_mouth
    oh i see. can u guide me how to uninstall HP wireless assistant? also, i can't find vista's in-build feature to control wlan.
    i did try to stop loading up hp wireless asst. during startup. but it had no effect. it would still take 2-3 mins to startup...
  4. shuvo
    To Uninstall
    1. Go to Control Panel > Programs & Features
    2. Select "HP Wireless Assistant" and click uninstall
    You should be able to uninstall the program from there. However, becareful since you may loose your wireless settings, if any.
    To use Vista's in-built:
    Go to Control Panel > Manage Wireless Network
    or
    Go to Control Panel > Network & Sharing Center
  5. Thaoster
    Thaoster Notebook Consultant
    I have hp wireless assistant installed and I don't have that problem. I think it's something else. But then I did a fresh installation of XP so I really don't know the exact cause for the slowdown.
    I suspect when you log on it's trying to authenticate to a server or something.
  6. cotton_mouth
    ok thanks! yeah i uninstalled it and it loads up in about 30 secs now. but now i have another problem. u see, hp wireless asst helped me to turn on and off my wireless lan and bluetooth. hmm i usually don't need to use bluetooth so i always keep it turned off. however whenever i startup my com, bluetooth is automatically turned on. anyway i can turn it off and on whenever i want to? thanks!
    oh and dun worry, i still have the file to install HP wireless asst if smth goes wrong.
  7. cotton_mouth
    yeah the problem doesn't exist for winXP. my dad's comp has XP installed and he doesn't have that problem so yeah.
  8. shuvo
    hmm. My brother's dv8300t has a button on top of the keyboard to turn WLAN and Bluetooth on/off. I'll let you know if I can find any other way. Lets hope someone knows it :)
  9. Lithus
    Lithus NBR Janitor
    You can go into the device manager and disable bluetooth if you never use it.
  10. cotton_mouth
    hmm i also have a button to disable or enable wireless. but it's not useful cos it disables both bluetooth and wireless lan. as far as i can find after doing a google search, vista doesn't have any feature which allows u to just turn off bluetooth while keeping wlan turned on.
    guess the only option to turn off bluetooth is using device manager...but i wish vista had a button on system tray like XP where u could turn bluetooth on or off.
