HP Probook 4530s screen upgrade 900P, 1080P
Discussion in 'HP Business Class Notebooks' started by timohour, Dec 22, 2011.
  1. r00kis
    r00kis Notebook Enthusiast
    Hi Everyone,
    Anyone ever heard of the cable 648977-001? This is what I got when I ordered 646274-001 from HP Parts. Initially, I thought about returning it, however, since I had my 4530s dissisembled I decided to test it, and guess what it works.
    However, after using it (with B156HW01 V.4) I noticed that it causes a severe eye strain (its hard to focus when reading something).
    Now I am not sure if its my screen, cable or just my screen needs calibrating?
    Thanks for your input
  2. r00kis
    Webcam has its own cable, therefore, no you do not have to ugrade/replace it.
  3. NinjaOne
    NinjaOne Newbie
    Thanks!
    Assuming my bios version is current, do I need any software/firmware patches to make this work? (I saw on a Hackintosh forum that it they needed a dual-link patch to make it work, but I was unclear if that was only to make it work with Mac OS)
  4. r00kis
    Your assumption is correct. Dual ink patch is for Mac.
    My laptop came with Bios F.23 and I had no issues (plug&play basically).
  5. jar50972
    jar50972 Newbie
    I remember reading that certain 4530s models don't work with the screen upgrade. I really want this notebook because of the ability to run Mac OS, but the screen is subpar. So if I can upgrade it to 1920x1800 1080p, that would be good.
    So back to the question,
    Is there any model that doesn't work? Or can I just go on eBay and buy the first one I see?
  6. Porzeczek
    Porzeczek Newbie
    Okay, i can confirm that this upgrade works with 4530s (A1D13EA) + B156HW01 V.4 + 648977-001 (ordered as 646274-001).
    And one question: is anyone of you experiencing some high frequency noise when dimming panel?
    P.
  7. timohour
    timohour Notebook Consultant
    Never had such a noise. But I have an LG panel
  8. mahdi0
    mahdi0 Newbie
  9. alex_r
    alex_r Newbie
    Hi all,
    What about model 4730s?
    Is it possible to change display to better?
  10. WiredBrain
    WiredBrain Notebook Enthusiast
    Again..
    Will this lcd upgrade work on the new probook 4540s?
Similar Threads - Probook 4530s screen
  1. fxckrio
    532
