hp pavilion print screen problem
Discussion in 'HP' started by yvonne, Nov 10, 2007.
  1. yvonne
    yvonne Newbie
    hp pavilion 9565ea
    the print screen option does not work
    On "help desk" advice I have uninstalled keyboard drivers and reinstalled them - no good
    I have seached hp for updates for drivers - I have the latest ones and the keyboard is "apparently" working properly.
    other forums have suggested pressing fn key - I don't appear to have one.
    some of the other function keys don't appear to do anything but some eg f5 inserts date and time
    I have no idea what the icons on some of the keys mean eg (sun and arrow up or down) so don't know what they should do
  2. timtravel42
    timtravel42 Notebook Virtuoso
    you have to press the fn key (it is located between the ctrl and windows keys)
    and press printscreen at the same time
  3. RaphaBR
    RaphaBR Newbie
    try FN + INSERT... on my keyboard this is combination for PRT SCR
    my keyboard is crazy too!
  4. yvonne
    yvonne Newbie
    thanks, I tried that a number of times without success, but eventually it did work.
  5. timtravel42
  6. tsaalman
    tsaalman Newbie
    Hi v3locity2.0,
    I know this was an old post; hope you're still around. I too have the print screen problem and have tried your solution many times without success. I've held down the FN key on my HP Pavilion notebook/XP Pro, and tapped the prt sc/insert button, but never have anything in my copy buffer to paste.
    My mouse control panel has a setting for jumping to the active button in a dialog box, but it never remembers this between login sessions. I wonder if they're related?
    Any help on the print screen issue would be greatly appreciated.
    Thanks,
    Todd
  7. flipfire
    flipfire Moderately Boss
    Make sure scroll lock is on/off
  8. deeastman
    deeastman Notebook Deity
    - Out of curiosity, what program are you trying to paste into?
    - Does the image show up in your clipboard viewer? (Start>Run clipbrd.exe)
  9. muriithi
    muriithi Newbie
    hi, have hp 530 and have tried to print screen using fn + insert but have no succeeded please help.
