HP Omen 17 review (Skylake/1070)
Discussion in 'HP' started by Mobius 1, May 23, 2017.
  1. GreatD
    GreatD Notebook Consultant
    Thank you Mobius 1.
    One more question please can you recommend me special tools used to pry open up the HP Omen 17 computer to remove the Base cover with ease and the least damage possible??
    Links or specific tools will be much appreciated if allowed on Notebookreview forum
    Many thanks.
    GreatD
  2. Papusan
    Why Toshiba NVMe M.2 ? You know they run hot and throttling easy? @Mobius 1 :rolleyes: Several of them run +80c in some laptop chassis. With end results as fast decreased drive remaining life and fully throttling:cool:
  3. GreatD
    Thank you Mobius 1.
    Links or specific tools will be much appreciated if allowed on Notbook
  4. GreatD
    I thought it would be an ideal fast drive to start up Windows 10 and could navigate lag free and play games with very little loading times instead of using a SATA SSD M.2 drive?
    I don't know what to do now, I've bought. Is there no heat sink material i can put under/on top of the M.2 drive? Sorry I'm a noob with M.2 SSD's... :p
    Please assist how if I add some sort of material or heat sink to absorb heat from the M.2?
    Please advise on the above questions. I really appreciate your input. :)
    Papusan likes this.
  5. Mobius 1
    Mobius 1 nͫٴiͤٴcͫٴeͤ੮Һ૯ ცɿ૭ ૭คעٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴ⎬⎛⎝⎠⎞⎨
    a card will do just fine, but take care since upper receiver plastic is kinda soft
  6. Papusan
    This is Toshiba NVMe PCI-e ssd's temp in latest Alienware 15/17 BGA models. Awful reading. Several have problem with this ssd...
    SSD overheating - SSD overheating - The heat KILLING ssd's in the new Alienware's
    And we go on with More of the sam ssd and pch overheating - ssd overheating - ssd's boil in your machine
    See the M.2 heatsink mod done Here You're welcome!!:vbthumbsup:
  7. GreatD
    A normal Credit card? That's all? Do I start from the top while the screen is open? If yes where should I enter the card to make a opening? Many thanks
  8. GreatD
    That's not good. I just bought the 512GB m.2 off eBay and seller doesn't offer returns :( :( I don't know what to do. Should I get a SATA m.2 like the Sandisk x400 or Crucial MX300 instead? :(
  9. Papusan
    If you still want NVMe, choose Samsung. Same for SATA as well.
  10. GreatD
    Ok now, If the seller doesn't offer returns on the m.2 listing eBay then do I have to open up a return case with eBay??
