HP Omen 17 2019 RTX 2080 VBios Modding (190W)
Discussion in 'HP' started by DaMafiaGamer, Oct 16, 2019.
  1. HoangThi
    HoangThi Notebook Enthusiast
    I cannot find 180W vibios. Do you have it
  2. RainbowRunner
    RainbowRunner Notebook Enthusiast
    Wow that is amazing! Might try the 190w myself. Quick question, the 10091 timespy graphics score you are getting with 150w vbios, is it with no gpu overclocking?
    Edit: typo
  3. matyee
    matyee Notebook Deity
    Hi,
    can I use the 200W vbios for 2080rtx in my 870km1? I used the 190W version it works fine and NO nvida inf mod is needed. I have vapor chamber even with 190W it is cool :)
    thx
  4. Papusan
    Papusan TURDBOOKs Sucks! Dont waste your $$$ on FILTHY
    matyee likes this.
  5. DaMafiaGamer
    DaMafiaGamer Notebook Deity
    I wouldn’t recommend this on a Clevo card, some are dying at 150w as it is lol. I know one guy who bought the gpu for his P870tm1 and it failed in only a matter of days (power rail failure).
    It’s funny to say this but some rtx 2080 bga solutions are better designed than their mxm counterparts this time around :D that is almost never the case usually.
    @Prema is correct to state that it isn’t safe. The only reason I used the aw 51m vbios on my hp was because it has the same mosfet management as the Alienware, which is surprising to say the least. Same mosfets and everything, just more of them (which are actively cooled too :))
  6. matyee
    not even the 190w? it works fine but then i go back to the original 150w. do you have an original 150w vbios? do i need programmer or can be flashed normally?
  7. DaMafiaGamer
    Personally I’d take the risk but most people shouldn’t as the card is more likely to burn out.
    @Prema has stated it is not worth the risk but if vrm cooling is good then you can take it to 200w no problem. It’s the same as the 190 anyway except the limit and the target are set to 200w instead of the target being set to 190w. 10w doesn’t usually make a difference, but power spikes of upto 220w on the 200w vbios is what can...
  8. matyee
    i have vapor for it but i do not want to risk, i follow prema guide :)
  9. DaMafiaGamer
    You can flash the hp 150w vbios, just make sure your laptop has g-sync support otherwise you might end up with a black screen.
  10. matyee
    i would flash the original clevo vbios instead
