HP OMEN 15 and 17 owners lounge
Discussion in 'HP' started by tweake628, Aug 23, 2017.
  1. RussellA
    RussellA Notebook Geek
    Hey, I just got a i7-10750H, 3070, 16 GB RAM Omen 15. It's got undervolting enabled, so I've set up a -0.1 mV on Core and Cache, disabled BD Prochot and changed Speedshift to 32. Anything else I should do?
    My current CPU temps stay in 70s and spike to low 80s at times, and my GPU stays in high 60s and spikes to mid 70s. I have a feeling I can get more performance out I guess?
    What are you guys doing in your throttlestop / afterburners with similar config laptops?
    Looking forward to some expert advice here
  2. willhub
    willhub Notebook Geek
    Is it possible to mod my HP OMEN 15-dc1045na to 115w bios, it's got a 2070 max q.
  3. cenkaetaya
    cenkaetaya Notebook Consultant
    Hi guys I am having an issue where when I reboot the laptop it always sits on a black screen for 2-3 mins before shutting down and restarting.
    This was right after a clean install, not sure what is causing this. I have installed all possible updates.
    AMD 4800H
    Geforce 1660 Ti
  4. Krzyslaw
    Krzyslaw Notebook Consultant
    HI
    I have OMEN 15 (2020) R7 4800H with RTX2060
    I want to repaste it with TFX paste and change all the pads for better ones. Does anyone know what is the thickness of stock pads?
  5. neit_jnf
    neit_jnf Notebook Guru
    Any info on F40 BIOS? my 2020 Omen 17 updated to it via Windows Update...
  6. Burrick
    Burrick Notebook Consultant
    All it says is
    - Provides improved security.
    - Provides improved system stability.
    Right.
    neit_jnf likes this.
  7. OneSickOmen17t
    OneSickOmen17t Notebook Consultant
    HP/Omen finally released the big boy customization options for sale. I9-11900H/3080 16GB. I wonder what the wattage for the GPU is.
  8. neit_jnf
    OMEN 17 (2021)
    Screen Size: 17.3" QHD 165Hz (2560x1440) or 17" FHD 144Hz (1920x1080) 100% sRGB
    CPU: i5-10400H or i7-11800H or i9-11900H
    GPU: RTX 3060 (130W) or RTX 3070 (140W) RTX 3080 (165W)
    OneSickOmen17t likes this.
  9. OneSickOmen17t
    Well after a year and a half I finally got Fan 90B error. I clean frequently but I think the bearing in the cpu fan went. $40 for new fans. Kind of a pain in the butt to do. Full heat sink removal and repaste. Also MX4 paste is garbage. I'm switching back to Kyronaught tomorrow.
  10. Burrick
    Did you get them straight from HP or somewhere else? Mind sharing where to get them? Mine are approaching two years old. $40 is not outrageous.
    Yes this machine likes Kryonaut, I also gave up on MX4 (which was fine on my MSI).
