HP g7-1113cl w/ AMD A4 Dual Core. Will A6 or A8 Quad Core Work?
Discussion in 'HP' started by Me109K6, Sep 12, 2011.
  1. Me109K6
    Me109K6 Notebook Enthusiast
    I just bought this machine from Costco for my son, and it is much better than I expected - especially video performance.
    Being the constant tinkerer, I noticed that the AMD A6 and A8 CPU's have the same socket and power draw, but they are Quad Core. Will this mobo support them? 'Wondering if there is a CPU upgrade path available for the future. Thanks in advance!
  2. R3d
    R3d Notebook Virtuoso
    They should work provided that the CPU is not soldered on (use CPU-Z to confirm that it has the FS1 g1 socket) but the real question is whether it can handle the heat or not.
  3. Me109K6
    Thanks, R3d. 'Didn't think about the possibility of a soldered CPU, although the online service manual 'implies' that it can be replaced in case of failure.
    As for heat, is there a significant difference if they both draw 35W? Also, do you know which chipset this mobo uses?
  4. wittynorseman
    wittynorseman Notebook Consultant
    CPUID - System & hardware benchmark, monitoring, reporting
  5. Me109K6
    OK, was unexpectedly busy the last couple of days, but here is the info from CPUID:
    AMD A4-3300M
    Socket FS1 (937) Hmmm - no mention of g1 in socket
    Mobo HP 3568 21.0A
    Chipset AMD ID1705
    Southbridge AMD A75
    Graphics Radeon HD6480G 512Mb Memory
    So, besides the heat, what do you guys think?
  6. Me109K6
    A gentle bump...
    Anyone have any thoughts???
  7. Izagaia
    Izagaia Notebook Evangelist
    I might question as to whether or not the BIOS would recognize all cores of the new chip. Odds are likely yes, but that's just me.
    Also, HP has been known to use different configurations of the same MB dependent upon the chip they are pairing it with. I.E. using a board configured to handle the power requirements of a dual-core CPU as opposed to using boards that could handle either dual OR quad core CPU's. The CPU's may even be of the same family and clearly meant to be interchangeable, however it does not necessarily mean that HP left that option open. But I simply may be over-thinking this.
  8. Me109K6
    Thanks, Izagaia - good food for thought. It sounds like the only way to really know for sure is to either contact an HP engineer or buy a used A6/A8 and experiment. The bummer with the latter option is voiding the warranty if there is some sort of security seal.
  9. Disgustipated
    Disgustipated Notebook Consultant
    I'll sell you my A6-3400M for like $50 if you want to try it out. I was planning on buying an A8-3510MX.
  10. Me109K6
    Thanks, Disgustipated - that's a very good price. :) However, I have to confess that I'm afraid to risk the warranty so early (the Costco version comes with a two year warranty). I'm thinking next summer, so I can hopefully find out more in the meantime - and I'll probably go all-in with an A8. :D
