HP envy + monitor problems
Discussion in 'HP' started by Justos, Sep 2, 2010.
  1. Justos
    Justos Notebook Evangelist
    Tell me what im dong wrong guys :)
    GPU is on
    Monitor is on
    minidisplay port - smaller version of dvi (cant remember the name) is hooked up. (I had to get an adapter because the original plug it came with wasnt supported on the envy)
    pressed F4, duplicate. Nothing changed at all.
    Went to power saving mode. F4 duplicate. The screen blinked and nothing still happened on my monitor. (it didnt blink in high power mode)
    I have a calypso monitor 24". Using it for college. Any ideas? BTW it is plugged in correctly, there is a flashing orange light and it says no signal then goes blank.
  2. MagusDraco
    MagusDraco Biiiiiiirrrrdmaaaaaaan
    I've noticed some people have issues with the minidisplay port and some monitors.
    but it's been hit or miss. Never used it before so I can't really help much beyond that.
    you are using the radeon though, right?
  3. Justos
    yeah i am... would my best bet be to get a USB convert instead instead of minidisplay?
  4. MagusDraco
    I have no idea.
    hdmi will work. maybe an active minidisplayport cable might work (apparently there are two types of those cables)
  5. tybert7
    tybert7 Notebook Evangelist
