HP EliteBook 8770w and 970M 6GB and 980M 8GB - they work!
Discussion in 'Hardware Components and Aftermarket Upgrades' started by artpra, Jan 13, 2016.
  1. wiggs
    wiggs Notebook Enthusiast
    OK, after installing drivers from HP (sp82364.exe) I have managed to perform somewhat sensible calibration using "sRGB" preset and 5700K whitepont in "Display Assistant":
    Attaching zipped report from DispCal. Note limitations of colorimeter though.
    @mirage_bg, may I ask you to do the following:
    1. Set screen brightness to 100% and leave bright window/object on the black background for ~5 minutes, then close the window and check if there is "afterimage/ghosting" left.
    2. Fill canvas with white and check if there is any colour-shift / bleed in the corners.
    All (I kind of hope people read this topic):
    • Do you experience any kind of coil whine? Especially in the top-right corner of the screen.
    • What's the difference between various revisions of LP173WF3 panel? http://www.panelook.com/modelsearch.php?keyword=LP173WF3 has SLB1/2/3/4 models, but I can't access datasheets to compare.
    Long live the 8770w! :vbtongue:
  2. mirage_bg
    mirage_bg Notebook Evangelist
    After overclocking my G.Skill DDR3L 1600MHz CL9 RAM to 1866MHz CL10 and heavily overclocking M5000M to 1400MHz core and 2700MHz mem, I got this results, which are ok for 7 y.o. laptop, I think...;)
    1. Yes, I have image retention on gray/dark backgrounds
    2. No, I can’t see any obvious color shift
  3. wiggs
    Thanks. What about coil whine, anything suspicious in the quiet room?
  4. mirage_bg
    Not with my current DC screen. My previous one had it though..
  5. Talzam
    Talzam Notebook Enthusiast
    Hello i just want to make sure i got this right, so dose the 970m/980m work with the 8770w with dreamcolour? all so how did you guys over clock the ram and can the cpu be overclocked i have the 3610qm? also i have the k5000m if that helps.
    Many Thanks
    Talzam.
  6. BazsiBazsi
    BazsiBazsi Notebook Enthusiast
    Just wondering, @mirage_bg do you still have the prema vBios files for the 980m?
  7. mirage_bg
    No, just for M5000M
  8. BazsiBazsi
    Oh sad, cant seem to find these files. Thanks anyway for the reply. Might play around with the editor to get out some extra juice when I get the card.
  9. mirage_bg
    Yes, they work. Even with DC display - they work.
    No, you cannot overclock the CPU in 8760/8770W.
  10. BazsiBazsi
    Why are people putting 3940XM in it then? Is it possible to change the multiplier?
