HP Elitebook 8560p Won't Shutdown
Discussion in 'HP Business Class Notebooks' started by DrOscillator, Apr 3, 2012.
  1. vaishakhi
    vaishakhi Newbie
    Amazing.... this thread should really belong in the general category for all those who've bought that generic caddy. This totally fixed the annoying 5 minute shutdown delay that my ASUS N56VJ was having. Thankfully my caddy was new enough to have the white tab and I didnt have to remove the terminals or rip the case apart. Reps to all those who helped :D
  2. ashjas
    ashjas Notebook Enthusiast
    +1 this switch works without any manual hack.
    thanks for the find ilyutza
  3. Tidra
    Tidra Newbie
    The best solution I found on forum EVER,...
    I have HP 4530s with Ebay clone cady and it works in cca 1 minute,...
    Thank you,
    Cheers
    I.
  4. Shack90
    Shack90 Newbie
    Works like a charm on Probook 4730s with a cheap HDD Caddy for MacBook. The pins are really small so you have to be very careful. I had to open the caddy case but it was worth it.
    Thanks guys!
  5. angellsl
    angellsl Newbie
    This thread saved me a laptop. I had this trouble since a couple of weeks, today a Google led me here. Bingo! A fine tip and sharp knife solved the problem. Thanks alot.
  6. ngoctan2512
    ngoctan2512 Newbie
    This thread just give me the answer that I want. I've got an Elitebook 8460p 5 days ago and install a SSD 3days ago and it can't shutdown
    I wanna Thank centaurian so much, cuz I did as what you had said and got an amazing result.
    THank you so much
  7. sudia
    sudia Newbie
    For the love of God, thank you so much, centaurian.
  8. thun88
    thun88 Newbie
    Thanks Centaurian,
    I've isolated the two pin with the tape.
    My laptop is an Asus K55VD, works perfectly. Now I can shutdown correctly :)
  9. HebronCL
    HebronCL Notebook Consultant
    Thanks!!!!!!
    now my Asus shuts down completely :D
  10. mehmet1279
    mehmet1279 Newbie
    thanks from Turkiye . I cut the third pin and It worked with my ASUS K56CB .
