HP Elitebook 8560p Won't Shutdown
Discussion in 'HP Business Class Notebooks' started by DrOscillator, Apr 3, 2012.
  1. Atavism
    Atavism Notebook Enthusiast
    I've had the same issue with a 2560p, although I'd rather describe it as annoyance then nightmare. It didn't cause any issues with windows for me, just that I had to hold down the power button nearly every time on shutdown. Either way thanks a lot for figuring out what the exact cause is and how to fix it. I didn't feel like cutting the small lead (and risking to damage something else while trying) and instead went ahead to isolate the sata connector itself. Cutting a thin piece of tape (transparent tesafilm in my case) and putting it over the connector pin works fine so far.
    MrMariusz likes this.
  2. emptyhb
    emptyhb Newbie
    Thanks you guys, i've fixed my problem. Hehe :thumbsup:
  3. mr-gr
    mr-gr Newbie
    Thanks a lot! It works for my Dell Vostro 3460 too.
  4. mr_c0w
    mr_c0w Newbie
    Thanks for the tip! I just used a knife to pull the pin out of the board. Works great so far on my 8460p.
  5. north.jani
    north.jani Newbie
    Thank you for information! Works great on 8560p! :notworthy:
    You are the best :thumbsup:
    RGD
  6. frizodanizzo
    frizodanizzo Newbie
    holy crap you're the best dude took about 1 minute to do with a pocket knife... my 8560w wasnt shutting down either, and this page was the first hit on google luckily i decided to go here. i just got the tip of my 2.5 inch kershaw in between the connector and the pin, then slowly pulled the pin from the socket, and that connection snapped off once i got it all the way pulled out. good job man works like a charm now i thought my workstation was ate up !!!!
  7. triopowell
    triopowell Newbie
    This information is invaluable! Much appreciated. :thumbsup:
  8. ilyutza
    ilyutza Newbie
    Thanks for the tip, this solved my problem;
    I found another way to do it, you don't have to dismantle the caddy :p
    My caddy has a small white dip switch next to S-ATA connector; changed his position and now the problem is solved
    I saw some different models and some have the switch inside caddy, others outside (one of the margins) 220000011346730622_10018762_2_image.jpg 220000011346730622_10018762_3_image.jpg
    TeodorSavic, Marrrius and HebronCL like this.
  9. ilyutza
    ilyutza Newbie
    LE: my 9mm caddy have the switch outside and i think the 12.7 have it inside
  10. Rick7221
    Rick7221 Newbie
    Thanks, this fixed my problem with my Dell Vostro 3450!
