HP dv8000t Reinstallation Guide
Discussion in 'HP & Compaq' started by MDesigner, Jun 30, 2006.
  1. MDesigner
    MDesigner Notebook Consultant
    LAST UPDATED: 7/1/06 2:00PM
    This guide is based off the knowledge from tph's dv2000t reinstallation guide. I found that a few things varied with the dv8000t, so after much pulling out of hair and swearing at the laptop, here's what I've come up with on how to do a fresh reinstall of XP on the dv8000t.
    1. First things first: BURN THE C:\SWSETUP FILES TO DVD!!! That directory will be too large for a single DVD, so split it up. Take the Media Center Feature Pack folder (MedCtrFP) and burn that to its own DVD. Then delete it from SwSetup, and then burn all the folders in SwSetup to DVD. This is absolutely crucial!! Without the drivers and apps in SwSetup, your laptop will be pretty much useless after reformatting.
    2. Double check that all your important data is BACKED UP!!
    3. Reboot, and enter the BIOS (F10). Go to the System Configuration page and set "SATA Native Support" to Disable. This is CRUCIAL!!
    4. Boot the Windows XP CD, and enter Windows setup.
    5. Hit Enter (continue). press F8 to agree with the legal stuff. Hit ESC (don't repair).
    6. Delete all partitions except the QuickPlay partition if you still have it. If you already removed it, you will have to recreate it.
    7. Select "Unpartitioned space" and hit "C" to create.
    8. The size will be whatever you want, minus 1028MB for Quickplay. Or if the QuickPlay partition already exists, put whatever size you want. For example, on my laptop, I set up three partitions: 1st partition @ 84338MB (for WinXP), 2nd partition @ 9970MB (for Linux "Ubuntu"), and 3rd partition @ 1028MB (for QuickPlay).
    8. Select main partition (1st one, biggest one) and hit Enter.
    9. Format NTFS. A full format is recommended if it's your first time formatting this drive. Otherwise, do a quick one.
    10. Windows will copy files to the HD after format.
    11. Reboot (it will auto reboot). XP install continues, this time in a slightly more graphical environment. Answer all questions it asks (which are mostly self explanatory. this guide is more about getting XP to work on the dv8000t, not a guide on how to install XP in general..you should already know that part)
    12. Windows will reboot again.
    13. Go through the brief setup process.. then Windows will log you in. You should NOT get any hardware wizards..especially for the IDE controller or IDE channels. If you do, this is bad news (make sure "Native SATA" in the BIOS is disabled!)
    14. Very first thing you'll want is the chipset drivers. Pop your swSetup DVD in the drive, and go to SwSetup\Chipset and run the setup. Reboot.
    15. Once back in Windows, click Start, click "Run" then type "devmgmt.msc" (shortcut to the device manager)
    16. Expand "IDE ATA/ATAPI Controllers" and right click on "Primary IDE Channel" and choose "Update Driver". If prompted to connect to Windows Update, always say no. Chooes "Install from a list or specified location".
    17. Choose "Don't search, I will choose the driver"
    18. Click "Have Disk", and browse to SwSetup\HDD, and click OK. Choose "Intel(R) 82801GBM SATA AHCI Controller", and click "Yes" to any update driver warnings you get.
    19. Reboot. (you should be prompted)
    20. Go into the BIOS, and enable Native SATA Support. Save & exit.
    21. Boot back into Windows. You will probably get more hardware wizards. Here's where things get weird, and we near the end of our install process:
    If a wizard comes up asking you where the heck iaStor.sys is, just point it to SwSetup\HDD. That will take care of that. If prompted to install the ICH7 Family Ultra ATA, just do default/recommended install and that should go away. Same with Primary IDE, you might get prompted to install that hardware, just choose the default recommended options and let it install. Here's the deal now, in the device manager (devmgmt.msc), you SHOULD see the following devices under IDE ATA/ATAPI Controllers:
    - Intel(R) 82801G (ICH7 Family) Ultra ATA Storage Controllers - 27DF
    - Intel(R) 82801GBM SATA AHCI Controller
    - Primary IDE Channel
    Basically, the DVD-ROM you have runs on the primary IDE. Your hard disk(s) run on the SATA controller. Simple as that.
    Get your video driver out of the way too. That's in SwSetup\Video.. run the setup file there.
    Now, look in the device manager under "Other Devices". There will be a bunch of question marks. go through each one and double click it, and click "Reinstall Driver". Always point the hardware wizard to SwSetup to find the file. No need for folder names, it will locate the right files. This will take care of your Ethernet port, wireless, Bluetooth, and several others. Only a couple drivers didn't work for me this way, "Unknown device" and "PCI Device". I believe one of these is the audio, I think the other is keyboard or touchpad. Audio is the trickiest of the drivers, besides the whole SATA business.
    Audio: go to SwSetup\1UAA\Disk1 and run setup. You may have to reboot. Go into the device manager again (Start->Run, devmgmt.msc) and look for a PCI Device with a question mark by it. It might be under "Other Devices." Reinstall/update the drivers for it, and just choose the default (recommended) options. It should say something about a modem audio device or something. Only AFTER that's installed can you go into SwSetup\Audio and run that setup file. It took me a while to figure that out.
    Install the touchpad software.. the setup file is in SwSetup\Touchpad.
    Install the QuickPlay software. SwSetup\QPW. This will also give you the MPEG2 codec you need to play DVDs and use the TV tuner.
    Install the QuickLaunch buttons. SwSetup\QLB.
    That's about all I can think of. if I'm forgetting something, please post a comment and I'll be sure to edit this guide to include it. After all is said & done, you should have NO "other devices" in the device manager, and no question marks. Everything should be accounted for. The only thing I can't help with is if you trashed your QuickPlay partition. I think you need to call HP and get them to send you the CD (450'ish MB). If you didn't touch that partition, SUPPOSEDLY you can run the setup file in SwSetup\HPQPDP and that will fix the boot blocks. I can't really verify that though. I have the QuickPlay CD and tried to install it, and I get this error:
    If anyone knows how to fix this, please post in this thread and I'll edit the guide.
    Hope this is helpful! Best of luck. If you have questions, post a reply and someone will help you out.
  2. ludayoda
    ludayoda Notebook Guru
    Thank you so much for this...I will try this process for dv5000t and see how it works. Very well done guide, instructions are explicit and detailed.
  3. aznron911
    aznron911 Notebook Consultant
    WOW THANK-YOU VERY MUCH!!!!!!!!!! MAD PROPS TO YOU! I will try this today sometime, and will let everyone know how it goes.
  4. nosabe332
    nosabe332 Notebook Enthusiast
    hi there. thanks for the thorough guide. will try tomorrow.
    anyway, over at notebookforums in the lengthy QP2.0 thread, another user had the same error message you got.
    unfortunately, his fix was just to leave enough unpartitioned space for quickplay, and it worked. you already account for this in your install guide, so i don't know what's causing it. have you tried leaving more than 1024 mb for QP?
    in the post, they say to make sure there is no drive letter associated with the unpartitioned space reserved for qp. just something else to keep in mind.
  5. aznron911
    I can't delete my windows partition says it contains setup files that are required to compelte the installation
  6. aznron911
    nvm fixed it!
  7. aznron911
    The only problems that I am having is the sounds. It says Driver Installation Failed: Coul not find the MEDIA device for this driver. Im pretty sure I installed the 1uaa file correctly. Any help would be great!
  8. MDesigner
    That's the tricky part.. after installing the 1uAA drivers, try rebooting. It actually asked me to install again, which I just picked "Recommended installation" and then it finally worked. I had a really hard time getting the audio to work.
  9. ludayoda
    aznron911, how did u fix the "contains setup files that are required to complete the installation" when you were trying to delete windows partition?
  10. aznron911
    make sure you have the boot disc in, and that you run the boot disc before you start the windows install
  11. aznron911
    k i fixed it but i did something different then you mdesigner. The way I did it was that you have to guy in the device manager and other devices you should see an exclamation mark on pci devices. Upgrade that device like you did with the other devices. But make sure you have the 1UAA installed first. The next step after you upgraded the exclamation mark is to run the setup in the audio folder. That pretty much does it!
  12. nosabe332
    all right, just attempted following this format. all good until i installed the hd drivers and rebooted. got stuck in the bsod flash and restart cycle. now i'm reformatting/reinstalling xp. more updates as they come.
  13. MDesigner
    I got stuck in the BSOD cycle too.. it's because I tried to install those SATA AHCI drivers by double clicking on the SATA controller in the device manager rather than the PRimary IDE. Did you happen to see two Primary IDE devices, by any chance? That might be why.. unfortunately I don't know which is the correct one. I do know that one really IS PATA IDE, and the other one is really SATA but it's confused since there's no SATA support (turned off in the BIOS). If anyone can clear this up, let me know.
  14. nosabe332
    I did see two IDE devices. both said "IDE channel". i'm not sure what changed this time around, but when i reformatted and installed windows xp the second time, a "Primary IDE channel" showed up, and i was able to install the ich7-m drivers for it properly. things look like they're working out.. gotta take care of more IDE stuff now, but it looks like the glitches are out.
    woot, thanks MD, that was helpful.
    ps. all this restaring/rebooting business is painlessly fast. there are absolutely no startup programs running now, and it takes about 30 seconds to restart the laptop.
    pps. for dv5000t users who are reformatting using this guide. MD suggested having the driver updater point to the general swsetup folder. my computer would not let me do that.
    for the ethernet controller, i pointed it to network. the same goes for the other devices, just pick some folders that look promising (i didn't write down the right choices).
  15. MDesigner
    That's weird that it wouldn't let you point to the SwSetup folder. It may not work for all drivers, but many of them will search all subfolders in SwSetup and find the right drivers. Maybe I'm off my rocker. I'm actually going to reformat & reinstall again, so I'll see how it goes this time around.
  16. MDesigner
    Guys, check the first post. I made a change..
    When you boot WinXP for the first time, and those hardware wizards come up, DO pay attention to them and keep clicking "Next". That will install the IDE controller. THEN you will properly have a Primary IDE & Secondary IDE. If you look at the "Advanced Settings" for Primary IDE, it should say UDMA 5.. this is your hard disk. Secondary IDE has a UDMA 2 device on it (your DVD burner).
    Follow the rest of the steps (update the driver for Primary IDE & choose the SATA AHCI driver).
    ****** EDIT: I take this back. I can't get it working now, I keep getting blue screens. If anyone has an idea, let me know. PS, if you keep getting blue screens, pick "Last known good configuration" when Windows asks you.. that will get you back in and revert the drivers back to the way they were before. I will post as soon as I have a solution to this annoying problem.
  17. MDesigner
    How funny.. I wrote this guide and now I can't even get it working myself. nosabe, when you got it working the second time around, did you let XP install the Primary IDE & Secondary IDE drivers? What about the PCI IDE controller? Did you install the chipset as soon as you booted, before the hardware wizards? AFter?
  18. joystik
    joystik Notebook Evangelist
    Hey MDesign thanks so much for writing this up, i would be so lost without it! +rep
  19. nosabe332
    hey MDe, let's see, to the best of my memory, i did install the chipset drivers before doing the PCI IDE controllers, which is what you recommend in your guide.
    i'm a bit fuzzy on what i did earlier, when i got the IDE controllers to work.
    the second time around, i saw "Primary IDE Channel" and rightclick-update driver-no, not this time-next-advanced-don't search-Primary IDE Channel-next. i think i clicked "next" instead of the "have disk" button. that's all i can say.
    right now i'm having problems with my wireless bugging out frequently. no idea why..
  20. aznron911
    Just wanted to let everyone know that this guide does work, or worked on my computer I had to do a few small things different but for the most part it works.
Similar Threads: dv8000t Reinstallation
Forum Title Date
HP & Compaq DV8000t randomly reboots... help Apr 3, 2009
HP & Compaq Can my DV8000T take 4GB of ram? Aug 18, 2008
HP & Compaq HP dv8000t reboots when playing games May 6, 2008
HP & Compaq dv8000t motherboard shot, replace or buy a new laptop? May 6, 2008
HP & Compaq Is the video card in a dv8000t replaceable? Apr 26, 2008
