HP dv5t stuck on "hp invent" screen
Discussion in 'HP' started by seamustry, Sep 16, 2009.
  1. seamustry
    seamustry Notebook Enthusiast
    when i turn on hp dv5t laptop, it stays stuck on "hp invent" splash screen.
    pressing esc or any f-keys does nothing. it just stays on the splash screen.
    it is still under warranty but i want to recover my data myself (i don't trust HP repair person will do it for me).
    is there a way i can fix this problem?
    thanks
  2. sendmarksmail
    sendmarksmail Notebook Evangelist
    They probably won't recover you're data. Best thing to do is buy a cheap $10 2.5" HD external usb enclosure. Connect it to another PC with enough space and back up all you're files there.
    You can find cheap ones at newegg.com. It's better than trusting HP with your hard drive. Worth the 10-15 dollars to do it yourself.
  3. seamustry
    but still i would have to remove the hard drive from the laptop and if do that, it will void my warranty.
    that's why if there is any way i can fix the stuck at splash screen problem myself, please do tell me.
  4. Lithus
    Lithus NBR Janitor
    Removing your HDD doesn't void your warranty.
  5. seamustry
    really? i thought if i even touch any screws on the laptop, it will void my warranty.
    is there anythign in writing about this? i doubt it's easy to remove the hard drive.
  6. Lithus
    Lithus NBR Janitor
    It's your warranty, so you find me the clause in your warranty that says "removing the HDD voids this warranty".
    A HDD is extremely easy to remove. Requires you to unscrew 2 screws.
  7. sendmarksmail
    I've upgraded my RAM and HD, and sent it to HP for repairs. No issues. Just take lots of pictures.
  8. flipfire
    flipfire Moderately Boss
    1) Pop out the battery pack
    2) Take out the AC power
    3) Unplug ALL USB and external devices
    4) Hold the power button for 30 seconds
    5) Start up using AC power only
    Ipods and other USB devices sometimes stop you from booting past the BIOS
  9. exercise
    exercise Notebook Consultant
    Like Fipfire says:
    I have a USB thumb drive that prevents my DV6 from going past the BIOS.
  10. seamustry
    i tried flipfire's method but it didn't work. i didn't have anything plugged in anyways.
    i read about resetting the cmos but that would definitely void the warranty. i'll try to see if i can get the hdd out.
    any other ideas? thanks.
