HP Compaq 6910p Full Review
Discussion in 'HP & Compaq' started by marmion, Jul 11, 2007.
  1. mfa81
    mfa81 Notebook Enthusiast
    anyone has a suggestion for a good backpack for this laptop ? 15.4 backpacks are too big for a 14.1 laptop... maybe a 14" backpack can fits better !
  2. Nautilus
    Nautilus Notebook Consultant
    Installed the Vista SP1, dont know if it's faster or not, but i notice there is a lil bit more HDD Space now. Weird.
  3. normdc
    normdc Newbie
    Has anyone been able to use the firewire port that's available on this unit? I know most people are probably looking to use it for camcorder interface, but I'm particularly hoping to hook up a firewire storage unit I have. I've already checked to make sure this port is enabled, so I'm not sure what else might be needed. Thanks
  4. Copyright
    Copyright Notebook Consultant
    If anyone else is getting the sound stutter problem when you move the volume bar on the taskbar just go to sound options and turn off the power savings feature for the sound. This fixed my problem. Maybe a driver version later on will fix this. Ive had two 6910P that both did this.
  5. jegmadar
    jegmadar Newbie
    I buy my new 6910p, but problem is left audio signal is in the center.
    It is normal or not?
    HP 6910P
    T9100
    2gb Ram
    120gb 7200rpm HD
    ATI X2300 Graphics
  6. yazzi
    yazzi Notebook Enthusiast
    this is normal, speakers are placed on the right/center
  7. MattB85
    MattB85 Notebook Evangelist
    I really hope the 6930p doesn't suffer from this problem.
  8. freemovie
    freemovie Newbie
    Has anyone has experienced working with Vista 64-bit with HP 6910p? I have tried and installed all the proper drivers on mine. But after I have installed a number of software on the laptop, Vista 64-bit begins to to become very unstable, crashes, blue screens, reboots.
    My 6910p has ATI x2300 video chip and has 4GB of ram.
    I believe the problem has a lot to do with drivers issue with certain hardware. Anyone knows?
    On HP website, driver sp38088.exe is for Intel Matrix Storage Manager and is suppose to fix
    - Fixes intermittent issue where the notebook may generate
    a "blue screen" error when an application sends an
    IOCTL_SCSI_MINIPORT command to the system.
    a "blue screen" error when running PCMark05.
    I install softwares such as Matlab, S-Plus and Miktex and system starts to crash a lot without even using any of them.
    but it does not work.
    I have tried Windows XP Pro 32-bit and there is no trouble at all, but 4GB of memory can not be fully accessed.
    Can anyone help me to solve the problem?
  9. cskzh
    cskzh Newbie
    It does! Asymmetrical speakers, again! :mad: :mad: :mad:
    At least, according to the newest quickspecs.
  10. yazzi
    Does anyone hve this wallpaper in 1280x800? I formatted and made a clean vista install, and i really miss it! :)
  11. Derrickt
    Derrickt Newbie
    Send me an email; I have that wallpaper.
  12. yazzi
    Here's some HP wallpapers :)
  13. XGameOnX
    XGameOnX Newbie
    Nice I was looking for this
  14. shadi_saleh
    shadi_saleh Newbie
    Hi, I'd just like to add to this thread.
    I bought my 6910p in October 2007. Came with T7500, 2GB RAM, 160GB HD, ATi X2300. Also it came with recovery/driver disks for Vista Business 32/64, and XP Pro.
    I have to say that I like this notebook alot. The keyboard is a pleasure to type on, dare I say even comparable to the Thinkpads. Performs really well, but the graphics card is so-and-so. Alas, performance in graphics intensive apps leaves something to be desired.
    The notebook never gets too hot under load, but the exhaust vent on the left side is like a mini-heater, pushing out copious amount of air . The fan, not very noticeable under light-normal usage roars to life when under load.
    Love the biometric security, but HP's credential manager software is a little buggy. I've had a bit of trouble using it with firefox to log on to websites at times.
  15. delatdecatsini
    delatdecatsini Newbie
    it's so sad that i deleted recovery partition by mistake and lost my recovery/driver disk .:( Anyone can help me by uploading disk image on megashare.com or rapidshare ? Thank you so much
  16. lefty
    lefty Notebook Geek
    anyone know when the 6910p is going to be upgraded, refreshed, or replaced? which models?
  17. Castaa
    Castaa Notebook Enthusiast
    I've had a series of problems with my 6910p with the Intel GM965/X3100 chipset. Running Vista 64 sp1
    My problems:
    1. Does not fully go to sleep or hibernate mode 50% of the time and hangs forcing a hardware reset.
    2. The SD card reader's driver randomly uses 40%-50% of the CPU usage causing serious system performance issues after a few hours of up. I've had to disable the SD reader to fix this.
    3. The screen flickers occasionally when running off the battery (adaptive brightness issue?)
    4. Rare random crashes where the whole machine locks up while doing nothing.
    5. The similar fan noise issues people have reported in this thread.
    I have the newest BIOS flashed and all the HP Vista 64 drivers offered on their site.
    Anyone having similar problems with Vista 64? :(
