HP 8770W DC and Vortex GTX 1070 Error 43 Problem
Discussion in 'Hardware Components and Aftermarket Upgrades' started by mirage_bg, Feb 14, 2020.
  1. mirage_bg
    mirage_bg Notebook Evangelist
    Hi guys!
    My previous GTX 1070 Standard black PCB died for second time within two months and I decided to jump on a proven MSi 1070, which failure rate is pretty low.
    The problem is I was’t familiar with the Vortex edition of this card and now every driver past 375.70 gives me Error 43 in Device Manager...
    Is there any solution for how can I deal with this except reselling the card?
  2. mirage_bg
    Anyone with some advises?
  3. Hirosake
    Hirosake Guest
    Maxware79 likes this.
  4. Maxware79
    Maxware79 Notebook Evangelist
    Yep. I grabbed a standard (not MSI) card that happened to previously be in a Vortex and I was getting error 43. It caused me huge issues for a number of days while I was trying different modded drivers. Without a driver installed I could see the vBIOS version in GPU-Z. With a quick search online I worked out that the wrong vBIOS was installed for my M18x. A quick flash of the right vBIOS and she was good to go.
  5. Maxware79
    I had a non gsync card but there was a gsync vBIOS installed. I think the non gsync card is 1BA1 compared to 1BE1 but check your hardware ID in device manager. I read through the list of 1070 vBIOS’ online and saw that mine was for a 1BE1 card instead of 1BA1.
  6. FranekX
    FranekX Notebook Enthusiast
    HI.
    How about using that previous 1070 vbios into the new one ??
  7. mirage_bg
    Tried it. Same. Vortex 1070 won’t let newer drivers install on every other system without hard modding the card.
  8. FranekX
    In your situation I would stay with this 375.70 version driver (if it displays all 3D correctly) and from time to time validate new drivers under Win 7 and Win10.
    I would just sit wait and check :) Was not that your goal for 8770W ?? you have achieved it. What else do you expect ? :) :)
  9. mirage_bg
    I replaced it with non Vortex 1070 and all is working perfect now - 441.87 with 10 bit per color
  10. FranekX
    Congratulations then.
    What does this "Vortex" stands for beside the Edition ? any hardware difference, bios ?
