HP 820 G2 monitor upgrade TN to IPS
Discussion in 'HP' started by 3dfx4ever, Feb 3, 2018.
  1. 3dfx4ever
    3dfx4ever Newbie
    Hello,
    as title says, I want to try upgrading the display of my HP 820 G2.
    I disassembled the display to see the precise model of my sample, and the screen is the following:
    B125XTN02.0 H/W:1A F/W:1 http://www.panelook.com/B125XTN02.0_AUO_12.5_LCM_overview_20803.html
    Here the detailed specs:
    Manufacturer: AUO
    Size: 12.5-inch WideScreen (10.2"x6.4")
    Resolution: WXGA (1366x768) HD
    Surface Type: Matte
    Backlight type: LED
    Video signal connector: 30 pin 1lane eDP LED socket
    Mountings: Side Brackets
    From what I've read on internet, it is not possible to upgrade tu a FullHd monitor, because a 2line eDP cable is required to manage resolution higher than HD. In this case thinks become more difficult, because I need to find the correct cable too (did someone do it ?).
    So I'm looking for a HD IPS display that matches my current display specifications.
    LG LP125WH2-SPT1 should be compatible, but even if on panelook it is reported as IPS, I find only TN version selling (maybe compatible).
    Do you think this upgrade is possible ?
    Can you help me to find the correct display ?
    Thanks in advance.
  2. 3dfx4ever
    3dfx4ever Newbie
    While Reading on the web, I found that for HP 820 G2 the cable is the same for HD and FHD monitors, while it is different the side of bottom part of the display (which goes behind the bezel) - so a different bezel is needed (aybe also different hinges).
    What is your experience ?
  3. 3dfx4ever
    3dfx4ever Newbie
  4. noccio
    noccio Newbie
    I have changed mine to LP125WH2 SPM1, works fine.
  5. 3dfx4ever
    3dfx4ever Newbie
    Thanks for sharing your experience.
    It seems very hard to find. Where did you buy it ?
    Thanks.
  6. noccio
    noccio Newbie
    I have bought it at aliexpress.com, there are still some suppliers with stock, but notice it was 2 years ago, so maybe there are newer versions available. Anyway, I still can recommend mine after 2 years.
  7. IchRobto
    IchRobto Newbie
    @ 3dfx4ever: I am thinking about upgrading my 820 G2 display, too. Was wondering what display ended up buying. Thanks in advance for the help.
