HP 6930P Questions
Discussion in 'HP' started by Johnyjf, Feb 21, 2020.
  1. Johnyjf
    Johnyjf Newbie
    I have a couple of questions about upgrading my 6930P. The first is about the display, if I replace my 1200 x 800 ccfl display with a 1440 x 900 ccfl display will it work or do I need to change other components?
    The second about the hard disk, given it has a SATA II interface and that I do not use it for manipulating large files is there an benefit to using an SSD compared to an SSHD? Thanks for nay help.
  2. senso
    senso Notebook Deity
    There is always a benefit of using an SSD, much lower access time being the massive upgrade between an SSD and an HDD, plus lower power usage, and no noise/vibration, given the price of SATA SSD's vs an SSHD, go for a SSD.
  3. Johnyjf
    Johnyjf Newbie
    Thanks very much!
  4. Johnyjf
    Johnyjf Newbie
    To reply to my own question I just fitted a 1440 x 900 display in place of the original 1200 x 800 one and it works perfectly.
