HP 17 Screen replacement - help?
Discussion in 'HP' started by Quicklite, Dec 22, 2017.
  1. Quicklite
    Quicklite Notebook Deity
    Got a HP Pavilian 17 laptop (17-ab051na) with Core i7 & 960M Graphics & 17.3" FHD IPS screen. There are quite noticeable brightmarks on the screen, so I'm thinking about replacing the screen. I can only track down the IPS panel for AB200NA (Core i7-7700HQ, 1050 GTX) - from what I understand, it's the successor to the 6th gen model. From the info I can find on LaptopScreen.com - the panels spec seems the same?
    6th Gen (what I have): http://www.laptopscreen.com/English/model/HP-Compaq/PAVILION 17-AB051NA/
    7th Gen (model of the screen I can find): http://www.laptopscreen.com/English/model/HP-Compaq/PAVILION 17-AB200NA/
    This is the screen I can track down:
    http://www.ebay.co.uk/itm/New-HP-Pa...177132?hash=item544c4a182c:g:H-oAAOSwHnFVwyTj
    If I were to swap the screen (intended for the 7th gen model), in theory it should work, right?
  2. Andrew Baxter
    Andrew Baxter -
    Sounds like it's the same laptop with the same same chassis but just a different processor so it's a yes on that, but you could check with the seller first, just message via eBay. The HP parts and replacement document for this laptop is here: http://h10032.www1.hp.com/ctg/Manual/c05759407, page 66 they have the disassembly. You could ask the seller to verify the screen has the pin connectors in the same location as indicated in the guide.
    Good luck!
