[HowTo] SO-DIMMs Extreme: Boost 1600 to 2133 and beyond / JEDEC & XMP
Discussion in 'Hardware Components and Aftermarket Upgrades' started by James D, Jan 4, 2012.
  1. LaPioute
    LaPioute Newbie
    Hi residualvoltage, james d,johnksss
    you can send me the profiles Thaiphoon Burner for memory:
    my original TP profiles
    Samsung M471B5273DH0-CK0 China 1235.thp 2x4GB
    and
    Samsung M471B5273DH0-CK0 Philippines 1220.thp 2x4GB
    Thank you very much
  2. visp
    visp Notebook Enthusiast
    LaPioute
    Try this: Open your dump. Click editor tab. Choose DDR3 Speed Bins: DDR3- 2133L and click NEXT. Choose Reprogram SPD EEPROM with new SPD data. Apply and done. If it doesn't will be stable, please do not blame me.
  3. Col100
    Col100 Notebook Enthusiast
    I have searched everywhere but cant find any info.
    Has somebody tried or knows if corsair vengance CMSX8GX3M2A1600C9 will work as cas latency 8 ?
  4. Red Line
    Red Line Notebook Deity
    Hey there) Need some help to figure out why my kit doesn't run at advertised speeds. Purchased this
    Newegg.com - CORSAIR Vengeance Performance 8GB (2 x 4GB) 204-Pin DDR3 SO-DIMM DDR3 2133 Laptop Memory Model CMSX8GX3M2B2133C11
    But it clocks the modules at 1866Mhz CL11 only. Is this a thing with Haswell laptops and is it possible to play around it using Thaiphoon burner, eg.
    Laptop - Alienware 18 (2013), tried to put 2133mhz in the bios - no luck as well. Laptop boots with the same 1866Mhz speeds. Any help appreciated! Thank you
  5. visp
    Hello,
    Can you give us thb dump?
    Thanks.
  6. 2-Girls-1-Pudge
    2-Girls-1-Pudge Newbie
    Hello guys,
    i got a clevo laptop and want to know if its possible boost my ram from 1600 to 1866
    this are the specs 2x4gb
    Module Part Number: KHX1600C9S3/4GX
    Memory Speed: 800.0 MHz (PC3-12800)
    Timings 9-9-9-27-39 1T 128tRFC @1,5V
    I saw that Geocake flashed his kingston hyperx 1600mhz to a corsair vengeance 1866mhz.
    is it the same as i got?
    http://forum.notebookreview.com/ali...enchmark-thread-part-4-a-234.html#post8381346
    btw I there is a option in intel xtu which can change the my ram speed and timings. is there a difference that i should prefer this app?
    my intent was to save the 18eggs and ask u for the timings which i can mb chance myself in intel xtu.
    sorry for my bad english guys ^^ but i hope youll be able to understand me =)
  7. Meaker@Sager
    You could edit your own to the new speed to be honest.
    Here are my current settings on my P570WM:
  8. 2-Girls-1-Pudge
    thank you for your reply Meaker.
    is there any difference between boosting dual and quad channel?
    will the timings stay as told for 1866 settings or just for 2133?
    do you have the same rams as me?
    and what have i to do if the laptop wount boot?
    just pull accu out and pull the rams out or have i to disconnect my bios battery?
    will the settings then be restored by themself?
    im just scared thats why i ask that much.
    if i do it for 1st ram and if i have success then the 2nd and if not put
    both in and then put settings back on the 1st one right?
    i know many question but i would be happy about your replay again =)
  9. Meaker@Sager
    Quad channel is just trickier than dual but it only applies to the clevo 570WM with the X79 chipset anyway.
    The timings and speeds are all dependant on how you set them, you should be able to do it in XTU. It will reset the settings if they don't work and if it really gets itself confused then you have to do a cmos reset.
  10. danielschoon
    danielschoon das it mane
    I just got Typhoon Burner today and started messing around with it. But my machine doesnt seem to handle the differences very well.. Everytime i try to run 3dmak, i get a black or blue screen.
    this also puzezls me since i said to use latency 10 in Typhoon Burner :confused:
    What results have you guys got with the 8gb corsair vegence sticks?
