How to upgrade my alienware M17x R4 to gtx 980m ?
Discussion in 'Alienware 17 and M17x' started by Ritz1209, May 16, 2019.
  1. Ritz1209
    Ritz1209 Notebook Guru
    I bought the motherboard not long ago where the seller told me a previously had a 7970m ati factory.
    At the moment the gtx 580 seems to post where as the 675 & 980m wont resulted with 8beeps.
    Where can i find the UEFI capable of vbios. I have never flash vbios before so im not really to sure.
    If i dont put the 580 in the laptop it won’t boot on the integrated gpu .
    What is the best next step as i was just about to do a new UEFI windows installation win 10 .
  2. M18x-oldie
    Thats normal the 120 Hz won't boot on the integrated.
    Ritz1209 likes this.
  3. M18x-oldie
    Well now it becomes a bit tricky, you'd need either a UEFI capable vBios or GPU.
    At the time of my upgrade, I luckily had a 780m Clevo which is capable.
    In the meanwhile I sold that card, now have 660m, 675m with capable vBios' as backup card, I think i still have this 675m vBios file smwhere. PM me your mail, if I find it I will send it, you have a working 675m as I understood, correct?
    In the meanwhile you should start reading how to use nvflash :D:p
    You could also look over at TI, as far as I recall, svl7 had done some modded vBios for some of our R4s GPUs:
    https://www.techinferno.com/index.p...t-secure-boot-gpu-issues-solved/&tab=comments
    But downloading there takes alittle bit time and patience or a little amount of $$s.
    _
  4. Ritz1209
    Thanks again your help is much appreciated.
    Yes i got a working GeForce 675m which came from an M17x R4.
    I will start reading on how to use nvflash as advised.
  5. Ritz1209
    Hi mate,
    I got good news I’ve managed to get the GTX 980m to work.
    After reinstalling windows as UEFI GPT ad advised I tried the GTX980m into the laptop but was still getting 8beeps,
    Then for some reason i decided to plug in the HDMI cable into the laptop and was posting and detecting the 980m.
    Once in windows i decided to mod the 980m then install the nvidia driver.
    But wouldn’t post unless i leave the HDMI plug in.
    By disable all legacy and the boot change to UEFI and now everything seems to working fine now.
    All i can say is a big thank you for your help.
    Cheers
    Ritz
    uugui shi, M18x-oldie and rjtnag like this.
  6. M18x-oldie
    Super mate :)
  7. Ritz1209
    Mate ,
    I have noticed that my wireless connection keep on dropping like every 5 - 10mins .
    Have you heard of people having issues with their wireless network on m17 r4 something to do with the killer driver/card.
  8. M18x-oldie
    To be honest, I haven't heard anything. But maybe there's some problem with it.
    I don't have a killer card.
    Better open a new thread.
  9. uugui shi
    uugui shi Notebook Consultant
    I had a similar problem with my 17 R1 where I would lose connectivity every so often, I resolved it by using an older version of the driver that was already in windows. This had nothing to do with my GPU upgrade as it was a problem before I upgraded
    M18x-oldie and Ritz1209 like this.
  10. Ritz1209
    Hi thanks for you this, i will install an older version of the driver and see if this helps.
    Cheers
    Ritz
