How to upgrade my alienware M17x R4 to gtx 980m ?
Discussion in 'Alienware 17 and M17x' started by Ritz1209, May 16, 2019.
  1. M18x-oldie
    IMAG8346_BURST003~2.jpg Cannot tell from your photo but it looks like this. (Photo is with flash, it's not so clearly visible under normal light).
    Ritz1209 likes this.
  2. Ritz1209
    Ritz1209 Notebook Guru
    [​IMG][​IMG][​IMG]
    I hope this is ok
  3. M18x-oldie
    Ok that's 120 Hz, optimal starting point for GPU upgrade! :)
  4. M18x-oldie
    How's your BIOS' boot settings set?
  5. Ritz1209
    [​IMG][​IMG][​IMG][​IMG][​IMG][​IMG]
    I hope this helps im on legacy
  6. Ritz1209
  7. M18x-oldie
    Legacy needs to be turned off
    (and better also turn off fast boot and secure boot).
    And in order you need to reinstall windows completely under UEFI.
  8. Ritz1209
    Ok will try to reinstall windows under UEFI and see how its goes
    And looks like my bios wont allow me to change load legacy option rom if i try to disable it i get the below warning [​IMG]
  9. Ritz1209
    Will reinstall windows in UEFI and keep updated
    Thanks mate
  10. M18x-oldie
    You'd need a UEFI capable vBIOS for your old card, in order to switch this BIOS setting. This setting is essential. Your new card won't POST with 120 Hz when legacy active.
    Is your old card a 580m or 680?
