How to uninstall LightScribe Control Panel?
Discussion in 'Asus' started by fenrus110, May 18, 2008.
  1. fenrus110
    fenrus110 Newbie
    Just got my F8SN-B1, is this a Asus thing or a Vista thing or a Nero thing?
    I see it is in the folder: C:\Program Files\Common Files\LightScribe
    I run it, it tells me I have no LightScribe, fair enough. But I can't seem to find anyway to uninstall it. Plus it adds Service that I need to disable.
  2. red616
    red616 Notebook Consultant
    I have the same notebook but not the same dir/files you describe. Funny thing is someone asked a'while back if the CD/DVD writer on these notebooks (F8Sn) had the "Lightscribe" option. According to the Asus site they DO support Lightscribe , not that I've ever used it or even tried.
    Which service are you referring to ?
    You can view/edit services via Control Panel -> Administrative Tools -> Local Services
  3. fenrus110
    fenrus110 Newbie
    I see a Service called
    LightScribeService Direct Disc Labeling Service
    Used by the LightScribe software components to support 3rd party disc labeling applications using the LightScribe COM Application Programming Interface (LSCAPI). This service needs to run for LightScribe direct disc labeling to work.
    path to executable: "C:\Program Files\Common Files\LightScribe\LSSrvc.exe"
    Of course, I can disable it, but rather just get rid of it entirely if it is completely useless. Unless if I really do have LightScribe...
  4. niGht kiD
    niGht kiD .. beach boy ♫
    Uninstall from Control Panel -> Program & Features?
  5. fenrus110
    fenrus110 Newbie
    it ain't there for whatever reason...
  6. niGht kiD
    Do you see a windows installer package named LS_HSI in the Lightscribe folder? You can remove Lightscribe by running it. Or try to uninstall using CCleaner if it's listed in the program list.
  7. fenrus110
    fenrus110 Newbie
    found that .msi file. one less bloatware, thanks.
  8. sweetStyles
    sweetStyles Notebook Consultant
    EDIT: Ignore this fool xD. I didn't check Common files in the program files. #bangs head on table. Found the uninstaller. thanks for replying though.
    Cheers~
  9. E.B.E.
    E.B.E. NBR Procrastinator
    Deleting from the Start menu is certainly safe, but it won't affect the functionality (so if it starts automatically now, it will after that too). Better use msconfig to stop it from running, if that's what you wish.
Similar Threads - uninstall LightScribe Control
  1. HiddenDaguerreotype
    13
    2,590
