How to turn on bluetooth 4.0 on R2
Discussion in 'Alienware 18 and M18x' started by Heihachi88, Jun 5, 2012.
  1. DarkSkies
    DarkSkies Notebook Evangelist
    Not true. Killer 1103 does not have bluetooth.
    It is prolly switched off. In BIOS set the "wireless switch" button to work with bluetooth only. In this way your WLAN card will be on all the time and you will be able to switch bluetooth on and off.
    ^ Do that, then boot into windows, then press the button switching the bluetooth on, and THEN check then device manager.
  2. Speedy Gonzalez
    Speedy Gonzalez Xtreme Notebook Speeder!
  3. Heihachi88
    Heihachi88 Notebook Deity
  4. steviejones133
    steviejones133 Notebook Nobel Laureate
    4 screws - remove the base panel and you will see the card there. You will soon be able to tell which one you have!
  5. Quontum
    Quontum Notebook Geek
  6. Heihachi88
    When i received it - i immediately took it apart. Yes, there was killer 1103. But on my M17x R3 i replaced intel card with Killer 1103 but still had a bluetooth..
  7. Speedy Gonzalez
    I am afraid is going to be a little more difficult the bluetooth module should be behind the left speaker he need to remove the palmrest to see it
    if the company who sell the machine to him upgrade to wireless killer he don't have bluetooth :(
    best way to know is looking at the original specs on dell website with the service tag
  8. Heihachi88
    They can't say that even if i provide a Service code.
  9. Speedy Gonzalez
  10. Heihachi88
