How to turn on bluetooth 4.0 on R2
Discussion in 'Alienware 18 and M18x' started by Heihachi88, Jun 5, 2012.
  1. Heihachi88
    Heihachi88 Notebook Deity
    Hello, everyone. I just reinstalled windows and tried to turn on bluetooth but didn't found it in device manager and BIOS... What to do? Thanks in advance.
  2. steviejones133
    steviejones133 Notebook Nobel Laureate
    Make sure you have the blutooth driver installed from Dell Drivers & Downloads - can often be overlooked.
  3. Heihachi88
    When i install it - it says Switch to bluetooth on wireless... :\
  4. xmadror
    xmadror Notebook Consultant
    its a wireless+bluetooth combo card
  5. Heihachi88
    How can i switch? Via BIOS? i saw there's an option.. BT + WLAN, BT, WLAN. That's it?
  6. xmadror
    there is an option in the bios for sure (should be enabled by default, at least it was with my m18x) and you have an on/off switch with the media control between the eject dvd and the command center button
  7. Heihachi88
    Strange thing - i pressed on media panel to turn off wifi but it still uses it :D maybe conflict between killer wireless and with a dell one?
    EDIT. Now wireless button works - turns off and on my wifi connection, but what the hell with bluetooth -_-
  8. xmadror
    if the wi-fi is working the bluetooth should be working too
  9. Heihachi88
    I don't see any bluetooth devices in device manager...
  10. Quontum
    Quontum Notebook Geek
    Did your bluetooth work before reinstall?
    I'm pretty sure the Killer card doesn't have bluetooth, they would need another bluetooth module. Someone correct me if I'm wrong
