how to turn off the touchpad when using mouse
Discussion in 'LG' started by macoy, Jul 1, 2005.
  1. macoy
    macoy Notebook Enthusiast
    hello,
    I am using a LS 50a. everything is fine except that
    when I use the mouse, my hand also touch the touchpad occasionally which cause my pointer to move in a way that is unexpected.
    is there a way I could turn off the touchpad when I use the mouse?
  2. Venombite
    Venombite Notebook Virtuoso
    You may want to check the BIOS to see if there's an option for pointing devices. I think it's something like Simultaneous Pointing Devices or something to that effect. Just enable/disable this feature and when an external mouse is connected, the glidepad should auto disable.
    -Vb-
  3. Brian
    Brian Working at 486 Speed NBR Reviewer
    You probably have a manual function key for it as well, mine is FN + F4.
  4. macoy
    but how did you set it up? thanks.
  5. Xplodin
    Xplodin Notebook Consultant
    Macoy -
    If you are using the LS50 then the way to disable the mousepad is by pressing, Fn+F5 that should disable the touch pad.
  6. Brian
    There you go, I thought there would be a dedicated key for it.
  7. classicpromo
    classicpromo Newbie
    I am using a LG F1 Express Dual with Vista I use the Fn + F3 keys to turn off and turn on the Touch Pad
  8. shanx
    shanx Notebook Enthusiast
    On my T1, when i open the options for the onscreen display program, there is an option to automatically disable the touchpad when an external mouse is plugged in.
