How to turn off keyboard and other lights
Discussion in 'Alienware 18 and M18x' started by Salegy, Mar 22, 2012.
  1. Salegy
    Salegy Newbie
    Hi to all,
    Can anybody explane me how to turn off keyboard and other lights on my M18x ? The only thing that I'm able to turn off is the sign ALIENWARE under the display. All the other settings (keyboard zones, touchpad and other lights) allows me to decide the color but on the wheel don't allows black option (light off).
    Thanks
  2. steviejones133
    steviejones133 Notebook Nobel Laureate
    Look at the taskbar icons near the clock and you will see a small alienware head icon. Right click and you will see various options. To turn all lighting off, left click "go dark" and "go light" to change back....you can also dim the lighting from that menu also....make sure that "keep status zones on during go dark" doesnt have a tick next to it for total blackout !
  3. Salegy
    Salegy Newbie
    Thank you very much :)
  4. steviejones133
    Your welcome - have fun with your beast!
  5. jlyons264
    jlyons264 Notebook Evangelist
    Is there a way to turn off the macro key lights?
  6. AgentVFX
    AgentVFX Notebook Geek
    You can go into the alienFX program and just select the areas as black, as well as the macro i think.
  7. jlyons264
    Thank you +1. That must had been the only thing I hadn't tried...
  8. Flaick
    Flaick Notebook Evangelist
    Is there a way to disable the keyboard input? Usually my daughter is touching my Alienware :)
