How to simulate an exernal drive?
Discussion in 'Hardware Components and Aftermarket Upgrades' started by octavia, Apr 14, 2012.
  1. octavia
    octavia Notebook Evangelist
    I need to install a CD ROM of an Oxford dictionary on my netbook. The problem is that the activation requires to have the CD inserted on the first use. Using an image of the CD doesn't work. I talked to customer service and they said that there's no workaround. Anyone knows if there's something I can do to install it?
  2. chimpanzee
    chimpanzee Notebook Virtuoso
    usb based dvd ?
  3. octavia
    What is that? I'd rather not buy an external unit.
  4. chimpanzee
    borrow one may be ?
  5. octavia
    yeah, I think I'm gonna have to do that. i waned to check if there wasn't any other way. Thanks
  6. chimpanzee
    from the sound of it, this is a copy protection mechanism which need to read some info burn right on the CD/DVD that no ripping software would be able to handle.
    so i would say you need a physical media.
    just don't understand why this form of protection is still being used, it is so ancient.
  7. notyou
    notyou Notebook Deity
    An image loaded in with Daemon tools didn't work?
  8. moral hazard
    That should work perfectly.
  9. chimpanzee
    If it is a copy protection mechanism, it would not work as the ISO image you ripped from the CD/DVD has already lost the info the program wanted to see.
    This reminded me in the old floppy days when you need special coping program to duplicate a copy protection treated media and that war went on for years.
  10. AMATX
    AMATX Notebook Consultant
    Uh, you can get a dirt cheap external usb one for maybe $20 ??
    How much is time/effort do you wanna waste for $20 ?
