How to restore machine from PQSERVICE?
Discussion in 'Acer' started by andrewpmoore, Nov 7, 2008.
  1. andrewpmoore
    andrewpmoore Newbie
    I've recently offered to help out a friend who's Acer aspire has stopped working.
    It won't book into windows, but she is keen to keep her old files.
    I installed a 2nd version of windows onto the machine to basically back up the whole disk using acronis true image. I've now got that image storage remotley on my own machine.
    I think she bought the computer 2nd hand and never got a burned copy of the recovery disks and for some reason the Alt-F10 thing doesn't work to get into the recovery stuff (I've checked in the Bios for D2D)
    I've managed to make the PQService partition visible and was wondering what was the best way to restore the machine to factory defaults. I created a CD from the STCDBOOT.ISO file, which allows me to book into the recovery manager, but all it does is prompts for the first disk/system disk.
    I'm guessing that all the data required is held in the PQService partition, but I'm not sure how to create the backup DVD's that should have been done when the machine was first used.
    I would image that the data is held in the 92EPIXIE.nnn files in the D2D/images directory of the PQService.
    Any suggestions on how these files need burning to DVD to get the Recovery disk to detect them?
  2. Full-English
    Full-English Notebook Deity
    Is the D2D Recovery option enabled within the bios.
  3. andrewpmoore
    andrewpmoore Newbie
    Yes, but it still won't boot into it with alt-f10.
  4. Full-English
    I've found this on the ineternet, not sure if it will help:
  5. TeeJay 44
    TeeJay 44 Notebook Deity
    We are unable to announce the weather. We depend on weather reports from the airport, which is closed, due to weather. Whether we will be able to give you a weather report tomorrow will depend on the weather."
    - Arab News report
    Good play on words....
    Most won't get it though....
    Cheers,
    Theo
  6. TeeJay 44
    Sorry for the hijack...could not help myself though :D :D
    Cheers,
    Theo
  7. kiriakost
    kiriakost Notebook Deity
    You are forgiven my son ... :D
  8. andrewpmoore
    andrewpmoore Newbie
    Thanks for that. I had stumbled across pretty much the same information.
    What I ended up doing was doing an Acronis True Image backup of the drive.
    I then burnt the PQSERVICE disk from the backup onto a DVD (as when it's backed up you can see and extract the files on it)
    I then just ran the step:
    mbrwrdos.exe install rtmbr.bin
    and that replaced the MBR with the correct one, this then allowed me to get into D2D using Alt-F10 on boot.
    Thanks for your help.
    Andrew
