how to remove silkscreen logo from chassis?
Discussion in 'Notebook Cosmetic Modifications and Custom Builds' started by link626, Mar 23, 2017.
  1. link626
    link626 Asus GL502VM, Lenovo Y580, Asus K53TA
    I want to remove the orange logo on the lower right area of the deck.
    It feels raised, like silkscreen.
    The plastic is also textured to imitate brushed aluminum.,
    so I need a way that doesn't involve rubbing, which will blunt the plastic texture.
  2. Tinderbox (UK)
    Tinderbox (UK) Sir Pumpkin Longshanks
    I once read that you could remove the brand logo from a cell phone by rubbing the logo with a sugar cube edge, But were do you get sugar cubes these day`s i suppose a google search will give an more helpful remedy.
    John.
  3. kojack
    kojack Notebook Deity
    For this one I think your SOL. any attempt to remove that, will probably damage the finish on your notebook too.
  4. Tanner@XoticPC
    Tanner@XoticPC Company Representative
    I would not risk it, it's not a decal, so pretty much anything you do that will remove it is either going to abrade, nick or otherwise compromise the finish. You might have some luck with alcohol, but probably not.
    kosti likes this.
