How to remove scratches or at least lessen their appearance on plastic?
Discussion in 'Notebook Cosmetic Modifications and Custom Builds' started by Tinderbox (UK), Feb 26, 2017.
  1. Tinderbox (UK)
    Tinderbox (UK) Sir Pumpkin Longshanks
    OK, I don't want to be too specific how can you remove/reduce scratches from glossy/matt plastic on notebooks and monitors and mice and keyboards.
    What chemicals can be used to clean them without dissolving the plastic, what abrasives should be used, how do you restore the shine to glossy plastic.
    Any help appreciated.
    John.
  2. Tucker427
    Tucker427 Newbie
    Brasso and Silvo works great on hard plastics - removes scratches and gives a glossy finish.
    Tinderbox (UK) likes this.
  3. Tanner@XoticPC
    Tanner@XoticPC Company Representative
    If they're shallow scratches, some polishes/protectants like Plexus will fill in and make it look like they're not there, and also add shine back. Deeper scratches would have to be filled/buffed or painted over, and for matt surfaces you're out of luck if you don't want to repaint.
  4. link626
    link626 Asus GL502VM, Lenovo Y580, Asus K53TA
    some people take a scotchbrite pad and scratch up their glossy plastic.
    If you use the edge of a book as a guide, you can make very straight scratches to give it a fake-brushed aluminum look.
    some look like crap because their owners freehand scratched it, and the lines don't look straight.
