How to reduce input lag on a 13 R3?
Discussion in '2015+ Alienware 13 / 15 / 17' started by Reciever, Aug 11, 2019.
  1. Reciever
    Reciever D! For Dragon!
    I am considering selling my 13 R3 since the input lag is just too much to deal with when I am out of town. I like the machine and already made some changes to it so I would rather keep it, but if its unusable then I will part with it.
    I was wondering if you guys had some beyond the obvious tips for reducing input lag to the screen.
    Thanks
  2. eddi3x3x3
    eddi3x3x3 Notebook Evangelist
    Here are the tips you asked for
    1. Do NOT use vsync, it adds terrible input lag
    2. Unlock frame rate for games, the more fps you get, the less input lag. (This is true even if you only have 60 hz monitor, you get less input lag with 120 fps despite 60 hz monitor)
    3. If you want a tear free experience and you don't have gsync, consider using Riva statistics tuner and turning on Scan line sync. It's between vsync on and off and has way less input lag than vsync on.
    Sent from my Moto Z (2) using Tapatalk
  3. Reciever
    I dont use vsync, and dont limit FPS.
    Those are the obvious options but input lag is still very perceptible.
  4. yrekabakery
    yrekabakery Notebook Virtuoso
    1. Set max pre-rendered frames to 1
    2. Use a low latency FPS limiter (in-game or RTSS) and cap your FPS so that GPU usage does not reach close to 100%
    Vasudev likes this.
  5. Wilhelm_SI
    Wilhelm_SI Notebook Guru
    With what or where do you do that?
  6. eddi3x3x3
    Nvidia control panel, there should be an option to do so either per game or globally
    Wilhelm_SI likes this.
  7. Reciever
    Nvidia control panel within the 3d settings.
    I already have a framerare limiter and also prerender frames set to 1.
    Guess I'm just going to sell my 13 r3
    Vasudev and Wilhelm_SI like this.
  8. Wilhelm_SI
    Never really noticed that option there. But is nevertheless it is already at 1.
  9. Vasudev
    Are you perhaps using generic ngreedia drivers?
  10. Reciever
    Standard Nvidia drivers yes.
    I've already resolved to sell this laptop, it's nice I just simply never use it.
