HOW TO: Monitoring CPU and GPU Temperatures In-Game/In-Benchmark with On-Screen Display
Discussion in 'Alienware' started by Mr. Fox, Apr 4, 2012.
  1. Juscallmesteve
    Juscallmesteve Notebook Consultant
    The download you linked me wont install properly for some reason
    *EDIT
    I made a mistake
    And your suggestion fixed my problem. I am now able to monitor in Watch_Dogs
    Mr. Fox likes this.
  2. Mr. Fox
    **Bumped**
  3. JadePhoenix
    JadePhoenix Newbie
    Mr. Fox,
    I am a noob to this and I just bought an Alienware 17 with Windows 8.1 64 bit and GEForce GTX 880M video card. I was wondering if my main objective is to be able the CPU, GPU performance with FPS for my laptop, which software would be more relevant without causing too much load to my system? Thanks in advance for the advice. Cheers.
    Mr. Fox likes this.
  4. Mr. Fox
    Hey, without exception all of us began as noobs. This will put almost no measurable load on your system.
    Download and install the latest RivaTuner Statistics Servers (v6.1.2) here: RTSS Rivatuner Statistics Server - Download
    Download the latest HWiNFO64 beta portable version from here: HWiNFO, HWiNFO32/64 - Download
    Choose a location to extract HWiNFO64... one where you want it to be placed permanently.
    Set it up following the images in the screen shots album below, choosing which sensor values you want displayed, which row, column, etc.
    <iframe class='imgur-album' width='100%' height="750" frameborder='0' src="http://imgur.com/a/UYC3s/embed"></iframe>
    JadePhoenix likes this.
  5. JadePhoenix
    JadePhoenix Newbie
    Fox, thanks for pointing me to the download links.
    I could get the cpu/gpu monitoring using HWinfo and RTSS works like a charm but do I need another software to post FPS stats in my game?
    Thanks!
    Mr. Fox likes this.
  6. Mr. Fox
    No, open up RTSS and turn on "Show own statistics" and then you should see FPS stats in-game.
  7. Ethrem
    Ethrem Notebook Prophet
    So I have been having black screens in Bioshock Infinite lately and today I started playing The Last Remnant and it did the same thing. I thought it was a video card issue but apparently its an OSD and Unreal Engine 3 issue?
    I turned off RTSS and closed HWInfo64 and was able to play TLR without another black screen, which were occurring very frequently before that.
    Any idea how I can fix this? Its going to really suck if I can't have my OSD.
    I've got RTSS 6.1.2.7305 and HWInfo64 v4.42-2280. Options selected - GPU0 and GPU1 voltage, core, temp, CPU max core temp, show own statistics to get the framerate from RTSS.
    Its nice to know it isn't my new cards but not so nice to hear it could be my OSD causing the issue.
    Mr. Fox likes this.
  8. Mr. Fox
    Have you tried tinkering with the toggle switch for Custom Direc3D Support, or switching between Viewport and Framebuffer, Vector or Raster in the RTSS Control Panel? Having the D3D support option enabled sometimes causes really odd behavior. If changing those settings don't stop it, try dropping back to the previous 64bit version of RTSS. It is hard to find online sometimes, but you can get it here.
    If you end up having to use the older version and find it works OK, go into the settings and change the check for updates option to "never" to keep it from looking for an update.
    Ethrem likes this.
  9. octiceps
    octiceps Nimrod
    Make sure to disable your Steam or Origin overlay as it can interfere with RTSS. Especially Origin 'cause it's completely borked right now.
    Ethrem likes this.
  10. Mr. Fox
    Good idea. The Steam and Origin overlay features, and the in-game community features are notorious from causing stupid behavior. I always disable those silly things. Using the RTSS Stealth Mode also sometimes corrects weirdness in certain games.
    Ethrem likes this.
