How to get into router settings??? Help
Discussion in 'Networking and Wireless' started by Nvidia, Jul 21, 2008.
  1. Nvidia
    Nvidia Notebook Consultant
    Ok, i need help fast. i had a problem and reset a trendnet TEW-631 router. But it erased all the settngs and i can get into the settings!!!!! 192.168.1.1 puts me to verizon settings (My modem) and it says the ip of the router i think, but if i type it in , it dowsnt work. i tried 192.168.0.1 and 192.168.1.10 but nothing is working.
  2. vashts121
    vashts121 Notebook Evangelist
    Open cmd, type 'ipconfig' and look for the default gateway, that's the IP of the router.
  3. John Ratsey
    If you've done a full hardware reset then it should have defaulted to the settings given in the manual.
    The modem shouldn't be confusing the matter, but temporarily unplug it while you try to talk to the router.
    John
  4. Nvidia
    Thank you so much vashts121.
    + 2 rep
    I dont have the manual handy though, so that wouldnt have helped. I thought they were all 192.168.1.1 or .0.1, but this one is 192.168.10.1. thanks though.
    +2rep
  5. vashts121
    No problem, and thanks for the rep. :)
