How to get fan control for my Asus laptop? Please help
Discussion in 'Asus' started by Amuse, Jul 25, 2008.
  1. Amuse
    Amuse Notebook Enthusiast
    I have a S62J. I downloaded fan speed programs but can't control my fan!
    I am just wondering how do I get ACPI and NHC to control the fan?
    The only time the fan moves is when I boot it up.
    My specs in my sig, S62J is the same as Z62J I believe.
  2. E.B.E.
    E.B.E. NBR Procrastinator
    Please note that fan control isn't working so well with new models, mainly because the programs (NHC, SpeedFan) haven't been updated to support the newer mobile chipsets. So, if you're running fan control programs, please uninstall them, they may make your fan stop or not run properly.
    Then:
    If the fan only moves when you boot up then some power management software or firmware is faulty.
    Are you sure it doesn't move, or does it move and you just don't hear it? What values do your temps stabilize at? Use e.g., RMClock to observe the temps.
    If you use a stress program like Orthos Prime, does your fan kick in? Either that should happen, or the computer should shut down due to heat (don't do this without monitoring the temps though, if they get too high shut down Orthos and turn off the computer, in case there are more bugs than the fan not running you don't want to melt your CPU).
  3. JuiceBox121
    JuiceBox121 Notebook Consultant
    EBE-Other than that, fan control isn't working so well with new models, mainly because the programs (NHC, SpeedFan) haven't been updated to support the newer mobile chipsets.
    Which stinks
  4. E.B.E.
    I have clarified the post... to highlight that fan control software might be what actually stops the fan.
