how to format external hard drive to fat 32
Discussion in 'Windows OS and Software' started by lookitsakyauk, Feb 20, 2008.
  1. lookitsakyauk
    lookitsakyauk Notebook Consultant
    i have vista with a ntfs file format and want to format my external hard drive to fat32 what kind of a program do I need to be able to do that?
  2. Gregory
    Gregory disassemble?
  3. kedu
    kedu Notebook Guru
    open up the command prompt or "run" and type:
    format (your drive letter) : /FS:FAT32
    I take it you have a very specific use for this, the fat32 file system is ancient and will not allow files over 4GB
    But remember you will lose everything on this drive when you reformat from ntfs to fat32 - so back up everything.
  4. Polsta
    Polsta Notebook Evangelist
    juct click on the drive in my computer and click format
  5. kedu
    kedu Notebook Guru
    not possible in Vista, ntfs >> fat 32 with a drive over 32GB. Command line is the only way to do it using windows itself without extra software.
  6. x64Man
    x64Man Notebook Consultant
    True, but if you want to add an external drive to the PS3 one must format it to Fat32, I just had to do this.
  7. lookitsakyauk
    thats exactly why i need to do this. I had an extra 80 gb 2.5 in hd so I decided to make it an external to use with my ps3.
  8. lookitsakyauk
    thanks kedu I'm formatting now looks like it's working.
  9. lookitsakyauk
    i did the command line like kedu said and the prompt pops up and I format. But once its done and I click on the drive thru my computer it says that the drive is not formatted. Can someone help?
  10. kedu
    kedu Notebook Guru
    You have to turn off UAC. In the control panel click on user accounts and turn off UAC for your account and restart your computer then try again.
