how to flash your bios with dos using a usb stick:
Discussion in 'Sager and Clevo' started by zfactor, May 3, 2008.
  1. zfactor
    zfactor Mastershake
    so you downloaded the files. then you made the usb stick BOOTABLE correct?? reboot and have a c prompt? and you copied the clevo directory to a folder on the usb stick as well?? you are welcome to pm me exactly what you did if i can help
  2. AlanP
    AlanP Notebook Evangelist
    The DOS booting USB stick opesn a DOS enviornment. It will only recognize a file name of eight characters or less.
    Therefore the Batch [.bat] file can not be named overclock, as this name has nine characters. It is easy to rename overlength files in windows, BUT edit the batch file to check the .rom name length also. The same rules apply.
    SO, the .bat file name must be eight or less letters.
    It contains a .rom filename of eight or less letters AND this
    name matches a file .rom that is also found on the USB stick.
    Your error message indicates that DOS cannot find the file: either the Batch [.bat] File [the command that you typed] or the instruction File NVflash.exe [the command in the Batch File] or the referenced .rom File [the name found after the -4 -5 -6] cannot be found. If you have located some of these files in a different directory on the stick, this error can also occur, as DOS does not search through Directories for you. Remember that DOS does exactly what you ask it to do, it does not have an error handling capacity.
  3. zfactor
    zfactor Mastershake
    oh idea.... did you rename the files? which bios download did you use can use post which you used here?? most of them were custom for certain people and they require the files to be renamed..
  4. OregonCoastGamer
    OregonCoastGamer Newbie
    Just want to send a huge thanks to Z for helping me through my update. I finally figured out what I was doing wrong thanks to him! Using 177.39 drivers for my 64-bit Vista NP5792, my 3d mark score went from 8390 to 8600. Awesome!
    EDIT: 3d mark settings were off xD! Still a nice increase.
  5. MKang25
    MKang25 NBR Prisoner
    **** that is a huge jump.
  6. dit_xi
    dit_xi Notebook Evangelist
    Imagine if you had no computer knowledge whatsoever and read the caption of this thread:
    How to FLASH your _??_ with _??_ using a _??_ stick.
  7. AlanP
    Does this make us Geeks?!!!
  8. OregonCoastGamer
    Installed 177.79 and the physX driver.... now I get a 3dmark score of 8800. This gets better by the second :D .
  9. Nirvana
    Nirvana Notebook Prophet
    what's your spec? 3dmark06 or vantage?
  10. OregonCoastGamer
    Sager NP5792
    Microsoft Windows Vista Premium 64-Bit
    17" WUXGA
    Intel Core 2 Duo T7700 2.4GHz
    4 GB DDR2 667 RAM
    1 GB Intel Robson Turbo Memory
    160 GB 7200RPM HD
    nVidia GeForce 8800M GTX 512MB GDDR3
    Scores were taken in 3DMark 06
