how to fix the keyboard stuck problem?
Discussion in 'HP' started by Boai, Jul 29, 2006.
  1. Boai
    Boai Notebook Guru
    i still havent find a way to fix~~~ help me please:(
    the ctrl key some time will auto stuck~ ~ i use dv5000 and my computer made in china
  2. brianstretch
    brianstretch Notebook Virtuoso
    FWIW, my stuck keys problem has diminished over time. Maybe the keyboards just need to be broken in? Not that I'm excusing HP for not getting it right the first time, laptop keyboards no longer being bleeding edge technology and all.
    You're probably best off following the massive stuck keys thread. The dv8000 series has the same problem, if not worse.
  3. Boai
    Boai Notebook Guru
    so sorry , i cant understand your sentence , please give me a little tip~
    what is "being bleeding edge technology and all"
    what is "best off following"
    thanks to much
  4. szabodabo
    szabodabo Notebook Geek
    Well, not to be mean, but if you are going to contribute to an English language thread, you might as well learn English first.
  5. brianstretch
    "being bleeding edge technology and all": I was making a sarcastic comment about HP's failure to make a correctly working keyboard.
    "best off following": the stuck keys thread I linked to is the most appropriate place to get answers for your questions.
    szabodabo: I suspect we should all go back to using Latin as the universal language, though I'd miss tormenting foreigners with English :D.
  6. SuperKungFu
    SuperKungFu Notebook Consultant
    Regardless the keyboard sucks, my shift, ctrl, and the left arrow keys sometimes get stuck. Meaning once its pressed, it stays down. Piece of crap machine, and HP support doesn't give a rats ass about you. Lesson learned= never buy from hp again.
  7. Boai
    Boai Notebook Guru
    im chinese speaker~ i cant understand latin language too :)
  8. qohelet
    qohelet Senior Member
  9. Boai
    Boai Notebook Guru
    thanks too much~ but i was disassembly that more than five times~ but it still had this problem~~
  10. mitchc05
    mitchc05 Newbie
    Try using a USB mouse instead of the touchpad. Since I have used an external mouse I haven't had a single problem.
