How to fix loose USB port?
Discussion in 'Hardware Components and Aftermarket Upgrades' started by techNOguy, Dec 24, 2007.
  1. techNOguy
    techNOguy Notebook Consultant
    One of my USB ports became a little wiggly and loose after I accidentally knocked the receiver that was plugged into it. How can I fix this or tighten it back up?
  2. NotebookYoozer
    NotebookYoozer Notebook Evangelist
    open it up and start soldering
  3. techNOguy
    What needs soldering?
  4. powerpack
    powerpack Notebook Prophet
    Duct tape and "crazy glue", just kidding I have never done, soldering sounds correct but am surprised it still works if solders have come loose.
  5. D3X
    D3X the robo know it all
    yep. Must of been the outer shroud/metal cage around the connector, this is soldered directly to a ground point and even if it's loose it doesn't affect connectivity. Ever seen those super thin USB drives that don't have the metal shroud ontop? see below:
    [​IMG].
    Unfortunately the only way to properly fix it is to solder that back onto the main board, but I wouldn't be too concerned about it.
