How to fix error code 0 when copying files to external?
Discussion in 'Apple and Mac OS X' started by thekatt, Feb 15, 2009.
  1. thekatt
    thekatt Notebook Enthusiast
    I am trying to copy some dmg files from my mbp to an external hard drive (a western digital 1tb essential, and a 250gb wd passport). I get this "error code 0" when I try to copy the files larger than 4gb. Now I heard that this is because it is a fat32 drive or something like that. Is there a way to fix this without buying a different hard drive?
  2. Captain Fail
    Captain Fail Notebook Evangelist
    Reformat the drive with a different file system.
  3. thekatt
    Amazing. (How do I do that) :p
  4. Budding
    Budding Notebook Virtuoso
    Note that if you format your drive to HFS+, OS X will be able to write to it but the drive won't be recognised by a Windows computer without appropriate software installed. If you format it to NTFS, you won't be able to write to it in OS X without appropriate software installed.
    To format, it is best to first backup the data, and then use either Disk Utility for HFS+, or Windows Explorer or some other formatting application for NTFS.
  5. thekatt
  6. Budding
    That tells you how to format to HFS+.
