How to FIX AW17R4/15R3/13R3 CPU Core Temperature Differential Issue
Discussion in '2015+ Alienware 13 / 15 / 17' started by alexnvidia, May 18, 2017.
Does your AW13R3/15R3/17R4 suffer from CPU core temperature differential?
  1. Yes, over 20C difference
  2. Yes, over 10C difference
  3. Tolerable, within 5C difference
  4. No, within 1C difference
  5. Yes, over 10C difference, received after March 2017
  6. Tolerable within 5C difference, received after March 2017
Results are only viewable after voting.
  1. Jayce 71
    Jayce 71 Notebook Enthusiast
    As you see, the cores are closely uniform, with the exception of core 1. I went really thin with the lm tim. Maybe too much so. On a lighter note, new mobo with 1070 Samsung memory!
  2. Jayce 71
    Vasudev likes this.
  3. Falkentyne
    Falkentyne Notebook Prophet
    Too thin of a coating. Use more, tin the heatsink with it too, use nail polish transparent to insulate the SMD resistors around the CPU (must be cellulouse based) and PLEASE use a FOAM DAM BARRIER around the CPU (you can attach it with nail polish also, the foam dam must be VERY compressible). The foam barrier is required to make 100% sure that LM will not escape anywhere and blow up the motherboard. And please use a pressure paper test with basic TIM to test mounting and evenness of heat sink before wasting LM on this..
    Vasudev likes this.
  4. Vasudev
    Take a look at your thermal pads to see if there is more uneven pressure on one side of thermal pads?
    You can follow what @Falkentyne said about making FOAM barriers to prevent LM leaking onto the board.
  5. Pete Light
    Pete Light Notebook Deity
    For the R3, with a 7820HK and kyronaut. if that's with an OC then that's actually not too bad and about right if it's premium (BF1, Witcher 3, Destiny 2 or PUBG etc) gaming temps
    Sent from my SM-G935F using Tapatalk
    Vasudev likes this.
  6. Pete Light
    Normally it's core 0 and core 2 which has the much higher temps, classic tripod design heatsink issue. In your case its is the lower bottom left of the chip. This is actually quite unusual. I suspect it's a lack of paste and not enough is spread over that core (take some pics for us when you open it). It's either that or your pads are too high under the CPU on the left. Check these also.
    Core0 is top left, core 1 is bottom left, core 2 is top right, core 3 is bottom right
    Vasudev likes this.
  7. Jayce 71
    Yes, Fallkentyne, this is very possible, as I use just enough to tin both surfaces to avoid runoff (around a 1/2 bb or so). Glad to know that the clear nail polish isn't just an urban legend... Never tried it except on speaker repairs. The barrier is an excellent suggestion, and I had been thinking about something similar, already. I have a few different ideas that should keep the lm isolated to the cpu die. Thanks for the help, and great suggestions, guys. I think she'll be a real beast with a bit more fine tuning.
    Pete Light likes this.
  8. Zerpy
    Zerpy Notebook Enthusiast
    Sadly the core discrepancy issue continues into 2018.
    This is a replacement model after 5 repair attempts on a 6820HK 17R3.
    Idle temps are fine but even with 0 GPU load and -0.080v underclock I can't run Prime blend without hitting throttling at 4.1ghz.
    I have everything I need to try to fix it myself but I've seen a lot of posts mention they didn't make any progress with Kryonaut. I have Conductonaut as well but will only use it once I can get those core differences down.
    Does the bending the arm trick work? Is there any new updates on fixing this other than repad + pray? :)
    Rei Fukai, hmscott and Vasudev like this.
  9. Rei Fukai
    Rei Fukai Notebook Deity
    i would buy k5-pro, and repad with k-5 do a repaste and see how your temperature's are. ordered k5 brought back my temps within 5 degrees of eachother when benchmarking and 3 when gaming. Temps where bouncing off 100 C. after the repad i repasted my laptop with conductonaut, and now my max is 70C when gaming and 65/66 when benchmarking (gpu max is 65C without a undervolt)
  10. c69k
    c69k Notebook Deity
    Maybe this will help. I had also temps over 90 c and core differences of 10+. Please read my post # 6745 http://forum.notebookreview.com/threads/official-alienware-13-r3-owners-lounge.797884/page-675
    Vasudev likes this.
Similar Threads - AW17R4 15R3 13R3
  1. Alfly
    1,742
