How to FIX AW17R4/15R3/13R3 CPU Core Temperature Differential Issue
Discussion in '2015+ Alienware 13 / 15 / 17' started by alexnvidia, May 18, 2017.
Does your AW13R3/15R3/17R4 suffer from CPU core temperature differential?
  1. Yes, over 20C difference
  2. Yes, over 10C difference
  3. Tolerable, within 5C difference
  4. No, within 1C difference
  5. Yes, over 10C difference, received after March 2017
  6. Tolerable within 5C difference, received after March 2017
Results are only viewable after voting.
  1. Papusan
    The clocks run 3.0GHz, bruh. Of course max temp will be lower the lower clocks sink due throttling:rolleyes:
    Vasudev likes this.
  2. Vasudev
    I don't know why upon running OCCT, CPU esp. locked ones just stay at 2.8GHz or 3GHz. Disabling that sensors of OCCT does the trick.
  3. Papusan
    Clocks as you can see, increased to normal level after the test was stopped/cancelled. And 7820hk is unlocked.
    Vasudev likes this.
  4. Vasudev
    I think OCCT is black-listed by Intel. On AIDA64 it works 100% of the time at turbo speeds.
  5. Papusan
    Then, why should OCCT suddenly stop working correctly with Alienware’s now? Have worked just fine before. Nothing has changed as far as I know.
    Pete Light and Vasudev like this.
  6. Vasudev
    Not only AW but all PCs with HQ chips. I noted it on my cousin's lappie from HP.
  7. Papusan
    Mind you... The screenie above was with HK chips running:cool:
    Vasudev likes this.
  8. Vasudev
    Yeah I know.
  9. Jayce 71
    Jayce 71 Notebook Enthusiast
    please delete
  10. Jayce 71
    Vasudev likes this.
