How to fix Avast Antivirus High CPU Usage
Discussion in 'Security and Anti-Virus Software' started by Spartan@HIDevolution, Mar 2, 2016.
  1. Spartan@HIDevolution
    So a while back, I noticed that my CPU performance was decreased. I tested using wPRIME running a 32M benchmark. Without an Antivirus installed, I would get a score of 4.9 seconds, with Avast Antivirus Pro installed, I would get 7.5 seconds (the lower the score the better).
    I then posted this thread on the avast support forums:
    Avast Antivirus Pro affecting CPU Performance
    No help was offered and I was just told that any Antivirus would cause a small hit on the CPU performance.
    I then installed NOD32 and Kaspersky Antivirus (separately off-course) and benchmarked again but I would get 5 seconds in wPRIME so that was all good and the issue seemed to only be there when Avast Antivirus was installed.
    This surprised me because according to the latest AV-Comparatives Performance tests, it shows that Avast Antivirus is one of the lightest solutions out there.
    I then submitted a support ticker to Avast which as usual, took almost 2 weeks to be answered.
    They suggested to change a few things which I did and now my CPU performance is back to normal, I am getting 5.3 seconds in wPRIME so a 0.3 seconds performance hit is fine.
    Here are the suggestions from avast! Support to remedy this problem whilst not really affecting your security:
    @Ethrem
    austin_wardy likes this.
  2. Tinderbox (UK)
    Tinderbox (UK) BAKED BEAN KING
    I have been using Avast for years because of the low cpu usage, I get free Kaspersky though my bank but i has high cpu usage, So no problems with Avast.
    I have an gadget that monitors my system top five highest cpu hogs and avast is rarly on the list.
    John.
  3. Spartan@HIDevolution
  4. Tinderbox (UK)
    Kaspersky use to use 90-100% during a scan, Avast is super light weight compared to that.
    I just checked Taskmanger and it has avast using 0% cpu, as it`s not scanning at the moment, when it does scan it might go to 25% but for 15min or so and then stops, I suppose how long the scan takes depends on how fast you cpu/hdd/ssd is and how many files it has to search though.
    John.
  5. Spartan@HIDevolution
    The right way to test it is, run wPRIME 32M benchmark with all threads which should be 8 if you have a 4 core CPU(go to settings in wPRIME) with avast! installed, then uninstall Avast and run the benchmark again, not immediately after a restart but after a few mins of being idle then see
    PS: Disabling all Avast Shields doesn't count, it has to be uninstalled to see the difference before/after, if you have time to do this that is, maybe take an image before uninstalling it
  6. downloads
    downloads Super Moderator Super Moderator
    As always, your mileage may vary. I've seen people say they dumped Avast because it was causing high CPU usage on their laptops and at the same time having tested multiple solutions, I chose Avast to run on my Atom-powered convertible, exactly because it has low CPU and very low RAM footprint while providing very good security.
    I'll check those recommendations though - I think I might want to consider disabling "intelligent stream scanning" as Avast tends to eat up quite a lot of CPU when I'm downloading multiple files @ 100mbps. I'm guessing that's the reason - it attempts to scan multiple files at the same time coming at it at a steady 12MB/s
  7. Spartan@HIDevolution
    Good idea, please try the above recommendations and tell us if you see a difference. As support said, this will not lower your security because once the file is downloaded, if it was malicious, the active file shield will block it anyway so no harm done.
    I personally dislike programs which do HTTP scanning, like I have a NOD32 license for 10 users valid until 2020 which is collecting dust as it slows down everything for me, internet browsing, downloads, etc. wish I could sell it
  8. Tinderbox (UK)
    Yeah, I disable Avast bloatware app that i dont want to pay for, it`s sill not to.
    Yeah, I have use Avast on my Atom cpu table as well, no high cpu usage on it`s tiny little 900 passmark cpu score, my i3 i am using now gets around 2500 points and that is quite low to most modern cpu`s
    Those that use torrent downloading apps can expect to have high anti-virus cpu usage as all files need to be scanned and zip files are extracted and files scanned individually in the background this can use a lot of cpu power.
    John.
    EDIT: Hi i found this 2015 AV comparison test, and they also rank them by cpu usage.
    http://features.en.softonic.com/windows-antivirus-comparison-2015
    John.
  9. Spartan@HIDevolution
    @downloads
    On the avast forums, one moderator said the following:
    Can you please delete this thread as I don't want to cause any security risk to anyone.
    Thank you
  10. downloads
    Let's leave it - it's valuable to know both what to and what not to do. Someone may come across it and find it valuable - granted not the way first intended.
    Also Some of these tips from support remain valid - only intelligent scanning and script scanning should not be switched off it said moderator is right.
