How to do to recovery PQSERVICE partition
Discussion in 'Acer' started by cleitongt, Feb 1, 2008.
  1. cleitongt
    cleitongt Newbie
    Hi guys, I did this mistake, formatted my HD and lost de PQSERVICE partition, but I can recovery ussing a program offers by ACER
    I create a step-by-step how-to-do for anyone can resolve this problem.
    1) Go to http://www.acerpanam.com/
    2) Choice your country
    3) In Drivers & Downloads clic in more...
    4) Select your product (in my case was Aspire 5000)
    5) In the end of list have a file name "Post Acer Disk Formatter CD ISO Image"
    6) Download this file, burn a CD-ROM with it.
    7) Put in CD-ROM drive on Acer PC and press F2, and change to star using CD-ROM.
    8) Only use Next-Next-Next.... and this program wil create the PQSERVICE partition
    9) Next put yours recovers factory CD/DVD and return to the zero mark.
    Ps: I´m brasilian and my english is very bad, so sorry. But I hope that this can help someone.
  2. jithin6g
    jithin6g Notebook Consultant
    Is it really true? Have u tested it?
  3. Telkwa
    Telkwa Notebook Consultant
    Yeah, sure would like to know if it's that easy. Lots of folks would benefit from this if it works.
    Just checked; the support site list for my Acer 5920 includes the cryptically termed "Post Acer Disk Formatter CD ISO Image".
    cleitongt, how did you come across this?
  4. falco
    falco Newbie
    I'm not sure I understand.
    This only works if you you already have a factory recovery CD/DVD? If you're computer doesn't come with one, does it work with a burned DVD you made from erecovery?
    Thanks.
  5. fmmb
    fmmb Newbie
    Its not working for me. This solution only formated my D: disk, without PQService partition - eRecovery still not working :confused:
  6. arilsonbm
    arilsonbm Newbie
    Cleitongt
    Sou brasileiro e não entendo nada de inglês, gostaria que vc pudesse me passar as orientações de como usar esse Post Acer Disk Formatter CD ISO Image, esse ele só é usado para fazer a partição de recovery do zero tendo o cd de fábrica, o que não é o meu caso, ou pode se gravar o cd tendo a partição no note para guardar em caso de problemas.
    Desde já agradeço a atenção dispensada!
  7. bigozone
    bigozone JellyRoll touring now
    i could be way off base here,,, but my understanding of the "Post Acer Disk Formatter CD ISO Image" is that it will re-establish the factory formatting structure,,,
    but i can't see such a small image file holding all the gigs of data that the PQSERVICE partition holds,, how can one CD hold the data that takes 3 DVDs to back up??
    just my stab at common sense and logic,
    bigO
  8. tajfo
    tajfo Newbie
    I successfully rebuilt pqservice partition and now I can recover my system using ALT+F10.
    We can rebuild hidden partition from original dvds or we can put into pqservice system made by us with all drivers, programms etc. I can write a tutorial how to rebuild pqservice partition if you like.
  9. Halac0ax
    Halac0ax Newbie
    Please write up the tutorial. I'm sure that everyone would love to know how to do it
  10. kiriakost
    kiriakost Notebook Deity
    This forum its full of people with energy , who wish to learn the ACER secrets .
    What they do are to learn by their own failures , realizing in the end .. that rebuilding the PQSERVICE from DVDs its not possible .
    Still its interesting to see those people trying .
    So be my guest, and try ones more .
    http://www.acerpanam.com/synapse/forms/portal20.cfm?recordid=5287&formid=3394&website=AcerPanAm.com&siteid=7117&words=all&keywords=&areaid=2
