How to disconnect and disable G50V or G50Vt lights
Discussion in 'Asus' started by ALLurGroceries, May 20, 2009.
  1. ALLurGroceries
    ALLurGroceries   Super Moderator
    I am not responsible for any damage this procedure may cause. PROCEED AT YOUR OWN RISK!
    This is how to disable all* of the lights on the lid of the case.
    *There will still be leakage from the LCD backlight, but it is very subtle and nowhere near the intensity of having the lights turned on. See my pics below.
    Make sure the power is off and your battery is out. Step one is to remove your LCD bezel (thanks David for posting the disassembly guide). Remove the 4 rubber screw covers and place them on a smooth surface. The adhesive on them will probably only last through one or two removals if you are careful. The rubber strips at the top on either side of the camera only need to be peeled a little bit on their widest sides to expose the screws, don't take them all the way off. Once you have taken the 6 screws out, start prying the bezel off gently. There is some adhesive near the camera at the top of the bezel, you may want to use a credit card or something to pry it away. Otherwise you might flex the bezel too much and break it. Be very careful.
    In the following picture I have the hinge covers off too, you don't need to do this, only the LCD bezel needs to be removed. Next, remove the connector from the gaming board (circled in red):
    Put the bezel back on. No more lights.
    When you unplug the game board the RoG logo turns white and is very very dim (leakage from LCD backlight):
    I started playing with it:
    If you want to keep the RoG logo lit normally like that, keep the game board plugged in, but remove all cables except the leftmost blue ribbon cable. To take the ribbon cable to the right out, push up the black plastic part to unlock it.
  2. Buhdahl
    Buhdahl Notebook Evangelist
    This is going to make a LOT of people happy :D
  3. Delta_CT
    Delta_CT Notebook Evangelist
    Lol....you snapped before I did :D
    Is there supposed to be more than one picture in your post? I only see one.
  4. ALLurGroceries
    Thanks for pointing that out, pic is back up (NBR Image Gallery must be buggin).
  5. Delta_CT
    Thanks! What I'd really like to do is to remove the ROG logo from the lid, but it might make more sense to just paint it over. I'd love to do a half-silvered thing so that I can still have it light up on occasion when Clutch figures out how to control the LEDs, but straight black paint would do the trick as well.
  6. ALLurGroceries
    I just wanted to be able to sleep at night ;)
    Getting rid of the logo would be sweet but if you disconnect the lights you won't really notice it since it won't light up.
  7. Delta_CT
    My bedroom has no computers, but I sleep pretty well anyhow.
    I don't dislike the lights half as much as the ROG logo. I would have preferred that the Asus logo lit up, Mac style.
  8. Delta_CT
    Fascinating! I think it does disable the ROG light entirely, the little bit you see might just be a little bit of the LCD backlight leaking out?
    This thread might be helpful to Clutch - if the LEDs pass through this data board, presumably there might be a way to control the board! Since removing the cable on the right turns off the horizontal LED (and presumably also the vertical ones), the behaviour of the horizontal LED is probably software controlled.
    Has anyone ever reverse engineered direct console?
  9. David
    David NBR Random Reviewer NBR Reviewer
    Nice work ALLurGroceries.... this is an excellent thread for those whom wants to permanently disable those lights.
    Thanks for sharing :)
  10. ALLurGroceries
    It must be leakage because it's not getting power, it's just got a transparent membrane behind it. You can see it clearly in this pic from the G50 Notebook Disassembly Guide:
